| | | Forums66 Topics128,154 Posts1,056,850 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Any of you guys ever dump over your entire tool chest? Well this dummy did, trying to push it up a small incline outside the garage, bottom drawer with all the heavy stuff popped out and it all went over. Screwed up the bottom two drawer guides and dented the hell out of the top box. Lid had to be banged out to fit again, all looks like sh!t now. It is a cheapy harbor freight so I won't loose too much sleep over it but it won't get me my 4 hours back that it took to put it all back together, I had 1/4" sockets travel 20 plus feet away. Managed to find everything. Friggen dork. Rant off, Idiot over and out. Oh and btw, I am indeed a wrench fetcher and will always be no matter how many posts I make
1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Nov 1995 Posts: 5,732 24601 | | 24601 Joined: Nov 1995 Posts: 5,732 | Anyone who hasn't had a moment like that in the garage hasn't spent much time in the garage. You're among brothers here. As my dad said, "What did you learn?" Whatever the lesson is, learn it and move on. Today is a better day
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Remember many years ago changing the oil in my GTO and as I just finished adding in the 5th quart of oil looked down to see it puddling around my shoes. 5-quarts of oil on the garage floor takes forever to clean-up. Best part was I got to walk to the store to pick up 5 brand new quarts! Never forgot to put the drain plug in again I can tell you that! As John said most all of us have had a day like that. All worth it though for a day like this. http://www.flickr.com/photos/advance-design_parts_co/8129179759/in/set-72157631867396207
| | | | | Joined: Oct 2005 Posts: 4,259 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,259 | I don't ever want to see my box go over. 12' long, 3' deep, it just wouldn't be pretty. But, any day in the garage, good or bad, beats any day not in the garage!! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Get caught under that one Mark and we'll be reading your obituary. I bought a tool cart from HF and put an eleven drawer tool chest on it. Thought it would be a little handier than rolling the big one around. It wants to go over every time I move it, even on smooth level ground. They put the wheels WAY to close together and if you get it at all top heavy it's real unstable. Been thinking bout putting a 3/4" plywood base under it and moving the caster out about 6" or 8" before I have the same disaster that your dealing with.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I had the exact same thing happen with my then new Stainless Steel roller cabinet and it was totally full. I was pushing it back into the shop up the approach incline and it went over. Well....at least I found some of the small tools I thought I'd lost. *^%(*#%!! Grrrr. The worst of it was it put some bends and dents in my brand new shiny toolbox.
I guess it may be more of a common occurance than I thought. | | | | | Joined: Jun 2012 Posts: 1,748 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,748 | Ever try to teach your friend that it is a bad idea to pull more than one drawer open at a time? Picking up after wards is fun to watch. Fixing the damage that was done to the truck it fell on not so much. At least we were lucky, no one got hurt.
Steve H
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Learned about that hazard when I was just a sprout Steve, but it was with file cabinets, not dads tool chest. Denny G
| | | | | Joined: Jan 2012 Posts: 843 'Bolter | | 'Bolter Joined: Jan 2012 Posts: 843 | there will always be days like this
| | | | | Joined: Jun 2012 Posts: 1,748 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,748 | Forgot about them file cabs, must be getting old..:)
Steve H
| | | | | Joined: Apr 2006 Posts: 273 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 273 | Anyone who hasn't had a moment like that in the garage hasn't spent much time in the garage. You're among brothers here. As my dad said, "What did you learn?"  What did I learn? 1. Not to stand on a 3-legged stool when wanting to reach far under the hood, because they're unstable I might get tooth-holes in my lower lip when it jumps out from under me, and my chin comes to a sudden stop on the rad. 2. Not to get frustrated and slam a tool on the concrete floor in case it bounces back and hits me in the temple. 3. To remember to reconnect the lower rad hose after flushing and adding new anti-freeze. 4. To remove the wedges from behind the rear wheels after letting the front end down from the jack, and trying to back out of the garage. 5. Check the fuse FIRST! And a bunch more.......  | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | One more: ALWAYS use the correct size screwdriver. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | One more: ALWAYS use the correct size screwdriver. | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Now this is funny, and has been very therapeutic. Anyone who hasn't had a moment like that in the garage hasn't spent much time in the garage. You're among brothers here. As my dad said, "What did you learn?"  What did I learn? 1. Not to stand on a 3-legged stool when wanting to reach far under the hood, because they're unstable I might get tooth-holes in my lower lip when it jumps out from under me, and my chin comes to a sudden stop on the rad. 2. Not to get frustrated and slam a tool on the concrete floor in case it bounces back and hits me in the temple. 3. To remember to reconnect the lower rad hose after flushing and adding new anti-freeze. 4. To remove the wedges from behind the rear wheels after letting the front end down from the jack, and trying to back out of the garage. 5. Check the fuse FIRST! And a bunch more.......  1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | I once had diagnosed a bad voltage drain and took it to a friend who is a whiz at electrical troubleshooting. He strongly suggested that I turn off the dome light.
I once drained a water heater to change out the heater element. After the longest time, I couldn't believe how much that tank held. Then I turned off the water supply to the tank. I don't know how much of the local reservoir I drained, but the City never called.
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I was unrolling some 2/0 wire and hooked the loose end on the tool box so it wasn't trying to coil back on itself. BLAM! The whole toolbox fell over.
| | | | | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | You have to keep an eye open for kids as well. Mine almost pulled a bookcase over on her trying to climb up it. Same thing with the tool box when I left a couple of the bottom drawers open. | | | | | Joined: Oct 2012 Posts: 38 New Guy | | New Guy Joined: Oct 2012 Posts: 38 | Ive never had that happen to my own as its to large to roll around and it just sit's in front of my bay. but when i was in tech school, we used the schools 40 inch top and bottom. one day we were in a hurry and the wheel caught the floor drain. tipped it right over, bend the bottom box all up, tools EVERYWHERE, the shop got silent and all eyes where on us. lol. | | | | | Joined: Aug 2009 Posts: 15 New Guy | | New Guy Joined: Aug 2009 Posts: 15 | You all convinced me to buy the new locks for the Craftsman 12 drawer I just bought off CL. There are no keys, but at $155.00 I believe I can afford to buy the new locks and use them when moving the box. I once saw a guy topple his fully loaded machinist tool tower (roller, middle, top and side shelf). The side shelf had a complete 0.00 to 12.00 inch wood boxed micrometer set on it. I just ran the other way. I didn't want to witness the aftermath. I guess when nobody gets hurt it's all good, but doesn't ease the pain to the psyche. Have fun and be safe.
Gary Sterner 53 1/2 T Panel Hold On Tight To Your Dreams ELO Ya can't make it idiot proof, they keep finding smarter idiots.
| | | | | Joined: Apr 2006 Posts: 273 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 273 | I forgot the most important one.
6. Put ALL the new rings on the pistons before putting it back together and starting it up.
| | | | | Joined: Oct 2005 Posts: 4,259 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,259 | Aren't some of those supposed to go in the pile of "parts not to be installed?" I used to work with a mechanic who had a lot of those piles. I remember seeing rings in some of them. | | | | | Joined: Jul 2006 Posts: 240 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 240 | Was at a buddys shop and his son was getting readyto put the motor back in his truck, motor tranny all bolted together hanging on the cherry picker. His dad told him soon after the install, "might as well pull it back out, you forgot to put the torque converter on it. I wanted to say something but he said NO they will learn to pay more attention next time.
You Learn more Listening than Talking
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I put compression rings in upside down on a Harley piston once. Made a mosquito fogger out of it. | | | | | Joined: Dec 2008 Posts: 59 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 59 | Rebuilt a 307 SBC once, realized I forgot to add coolant to the radiator. Shut her off before any harm was done. From then on I always make a notation on all orifices to add fluids before start up on a new engine.
"One thing about trains, it doesn't matter where the're going, what matters is, deciding to get on." - Polar Express
| | | | | Joined: Apr 2014 Posts: 35 New Guy | | New Guy Joined: Apr 2014 Posts: 35 | Another one is when repairing a extension cord always make sure you put the correct ends on. once I put 2 male ends on and shocked myself. | | | | | Joined: Apr 2006 Posts: 273 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 273 | Another one is when repairing a extension cord always make sure you put the correct ends on. once I put 2 male ends on and shocked myself. Don't feel bad. Once I repaired a leaky garden hose by cutting out the "good part". I put a female connection on each end of it, and when I went to hook up the sprinkler I stood there staring with the sprinkler in one hand and the hose in the other. It took quite a few seconds to realize how stoopid I was.  | | |
