0 members (),
89
0
Mod | | | Forums66 Topics128,049 Posts1,055,637 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | I am finally getting my 235 back together again. Over the years I have assembled a number of gasket sets, and I thought I had all I needed. Regarding the gasket that goes between the intake and outtake manifold (from the heat riser) it seems I have three new gaskets that fit a 216 but not the 235. The problem is the narrower bolts on the block side. Since it is a bit of a hassle and several weeks of wait to send the proper gasket to Sweden, why can't I just lop off those two misplaced bolt holes and use my existing gasket. The other two holes will keep the gasket aligned until the bolts are tight, then the gasket shouldn't go anywhere, eh? It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Sounds like a good solution. I'd use some hi temp sealer on this to ensure a good seal.
I didn't know there were any Swedes left over there, thought they all moved to my home town of Turlock, Calif.
Best of luck Jim | | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | Thanks Jim. My own hometown in Minnesota is so crowded with Swedes that I moved to Sweden for relief. One other question on the intake manifold, on the 216 there were a couple of holes cast into the upper front to hold the horn. Those holes aren't there on the 235 variety, what the heck will I do with the horn? Anyone got pictures? Karl It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Minor correction: those hole were not there on 235s after around 1954, when the horn-location changed (the style of horn changed in 1953).
Earlier (1941-1953) 235 engines/manifolds had the intakes with "horn holes".
"What you do with an intake manifold that does not have the buss/hole for the horn?" Good question. It will be interesting to see the suggestions.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Will it fit behind the grille? I think that the horn is there on my 40 SD. | | |
