0 members (),
132
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Got a shy friend that will be setting his newly restored cab back on to his newly restored frame and he's asked me to throw some questions out to you guys about the pre-made wiring harnesses. He's looking at the one Classic Parts of America sells that is made for his '50, 3100. He will be converting to 12v with an alternator but that's about all of the changes he will be making. Their claims are that the harness comes with complete instructions and is numbered for ease of installation. And it's only a hundred and a half.
At the other end of the scale, Painless and several others list harnesses for similar vehicles for $400-$600. Obvious differences being, plastic wiring with standard electrical terminals vs original color coded cloth with period correct terminals, bare necessities vs accommodations for power windows, door locks, AC, surround sound stereo, electric wipers, etc.
Never having installed one of the lesser expensive harnesses, my question to you'all that have is, how did it go? Was it worth the hundred fifty bucks and were the instructions indeed complete?
Thanks Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Denny, I've used EZ Wiring on my 37, back in 1999, and EZ Wiring on my Panel a year or so ago. Both have worked great. The Panel is a 20 Circuit with Mini Fuses. Cost 165 plus 17 for shipping.
...I looked at the more expensive ones but could not justify it. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the spendy ones are mainly because of the cloth covered wires, if that's not important the lower priced ones do the job fine
Bill | | | | | Joined: Jan 2012 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 162 | I installed the $150.00 one in my Suburban. It took me about 4 hours and was extremely easy. The instructions are easy to follow, IF, you have a working knowledge of your truck's electrical system. It does not come with anything fancy and is a direct replacement for the original style harness, minus the cloth covering.
Mitch | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | A couple of the high buck ones I've seen come complete with all the switches and light sockets included. I have considered going that route so that I don't have to try and tie new wiring into 60 year old sockets/connectors. Any thoughts or experince on this?
Larry
| | | | | Joined: Jan 2012 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 162 | The one from Classic has all the dash light sockets attached, as well as the pig tails with terminal sockets for the headlights. You use your same ignition and headlamp switch and gauges. It's basically a wire swap. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Ok guy, thanks, I'll pass it on to my buddy.
Tanks again,
Denny G
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Larry, the AAW kit is the best for completeness. Their Classic series does have everything, switches, Packard terminations and many other items great for renewing all. It is really nice but it is the most expensive for sure. You will need to buy or use a tool you have for the crimping/strain relief on the contacts. I used it on a TF. Very happy. Built my own from scratch also, very happy. But a lot of work, bought a used 80's Chevy truck fuse box ($15) and wired it to accommodate the TF, bought Packard 56 connectors and contacts, and wire and fusible links and other stuff, challenging but what else do I have to do. Does not really save money from the $150 kits.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | I have never wired anything before wiring my 51, i purchased the expensive kit. My take is this besides the wiring being coded and labeled witch made no difference to me it was overkill. If i had to do it over again I would just purchase the (BOX) from them and buy my own wire. Probably would cost a third of what I paid. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | The best thing about the pre-wired kits is that the wire is well colour coded and marked every 4-6" with the number and name of the circuit. This makes for easy troubleshooting. Without that you would have to make your own diagram and would still have issues with troubleshooting I'm sure. Just my thoughts. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I figure my time is worth $50 an hour to me. I don't believe I could build a harness from scratch in 3 hours. Plus no telling how much it would cost to buy a roll of each color and size wire you need. I'd go for the $150 one. | | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | I used an expensive one the first time (on my '50) and an inexpensive one the second time (on my Dad's '49) I'll just say that the first one was PainFULL and the less expensive one went together very easily.
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
| | | | | Joined: Sep 2007 Posts: 15 New Guy | | New Guy Joined: Sep 2007 Posts: 15 | I've have used both, a $450.00 Painless 18 circuit kit and the $179.00 Rebel 9+3 circuit kit. These kits are best suited for modified trucks, not so much if your restoring an original truck. The Painless kit had everything I needed to wire my truck including headlight pigtails, fuses and more. I chose that kit because I was building a '52 Chevy truck street rod from the ground up and needed everything to complete it. This kit was perfect because I have a late model GM column with ignition switch on column, electric wipers with delay, power windows and heater. I may add A/C later. Great harness kit, with a nice instruction manual. When I rewired my buddy's '56 Chevy pickup, also a street rod, I used the Rebel kit. His truck already had new headlight pigtails from NAPA and is really a pretty basic truck. The Rebel kit is a good quality kit for the money, easy to install and Made in the U.S.A. You'll need to purchase some items like fuses and tie bands to complete the installation. But hey, that's how they keep the price low. A nice harness kit, instruction manual not so good. Bottom line, you get what you pay for. http://rebelwire.com/Good luck!
| | | | | Joined: Sep 2013 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 93 | Decisions,decisions. I have read mosts the post on 3 forums and still have not made up my mind. Each kit has its good and bad points, either too expensive or issues with the quality. One example is on the EZ21 harness I read twice that installers have found problems with the termination on the back of the fuse block!! That my friend is the LAST place you want an issue on a dark lonely road. So my dilemma goes on. The saving grace is I don't need it for a couple of months. In the mean time I will just keep reading. The jury is still out. (Ya, I know, you get what you pay for) But, it's just WIRE,  BT
1947 GMC Truck 5 window, Long Bed 2008 Corvette Roadster 2008 Harley Davidson FXDL 2011 F150 Ecoboost 4X4 2015 Subaru Outback AWD "only the strong survive"
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | My time working on trucks, or anything else, after retirement is worth $0 to me. I don't have a big schedule. SO I don't factor my time in anything. DIY'ers can not do that. I do value my money and try to do what is smart. Smart= try to do things I can accomplish, try new things, Don't spend more money DIY than store bought. You can't do a better job than a kit, but you might save some money if your time is $0. Everything can be ordered online if you want and usually saves money. I do stand by my previous remarks.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2013 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 98 | I've done several and prefer the American Auto Wire, that is the best handsdown. Painless isn't and it'd be the last one I chose. A clue is the advertising policy, those that advertise the most need it and you see thier advertisements everywhere. One very big consideration is the turn signals, the ez wire, rebel etcetc kits will have the turnsignals built into the fusepanel circuitry and require modern steering column or you'll be playing master electrician tring to integrate a signal-stat add-on turnsignal switch into a system that isn't designed for it. Don't toss your dash lamp sockets, they are much better thn any modern sockets - like in the AAW kit - you just need the bits and pieces to utilize them. But the current aftermarket dash sockets are horrors - don't use them.
A shop is where you wash your hands before you pee.
| | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Just purchased mine from Classic Chevy Truck Parts. It appears to be very easy to install even if you have minimum electrical knowledge. Everything is numbered and full instructions are included. $149.50+shipping. Can't beat the price either. I was considering making my own harness also, but I couldn't buy all the wire and connectors for that price.
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Just purchased mine from Classic Chevy Truck Parts. It appears to be very easy to install even if you have minimum electrical knowledge. Everything is numbered and full instructions are included. $149.50+shipping. Can't beat the price either. I was considering making my own harness also, but I couldn't buy all the wire and connectors for that price. Nicely stated. I have used 4 for those harnesses - a good use of my money and my time. | | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | I'll be the proud owner of one next week . Thanks for all the feedback .
" STUCK IN THE '50'S "
| | | | | Joined: Oct 2010 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 55 | Well, I paid for the Painless harness, which "ojh" says he wouldn't do. I have very little electrical knowledge and had heard it was considered the "best". I'll not be using an after-market steering column though either (at least not the first go 'round). I plan on using the stock column, even though I'm running an AMC Pacer rack & pinion front end. Reckon I'll have to figure out how to splice in a turn signal switch...if I decide to use one. The ol' hand signals worked great when I had my first truck.
I've yet to start running any wires as I have so many other parts I'm working on. I knew that rebuilding one of these would be time consuming, but I didn't realize that it was getting all of the little things done would take so much time. Like striping and repainting the vent window frames, inside windshield molding, getting the stainless on the dash cleaned up, dome light, etc.
Look forward to trying the wiring. Hope it's as "painless" as they say it is. | | | | | Joined: Oct 2013 Posts: 122 'Bolter | | 'Bolter Joined: Oct 2013 Posts: 122 | Which companies sell the wiring harnesses with the original cloth-insulated wire? I have been unable to find one for my '53. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Oct 2013 Posts: 122 'Bolter | | 'Bolter Joined: Oct 2013 Posts: 122 | Thanks Tim. I believe mine originally had cloth-insulated wire, but have not gotten a definite answer yet. It is an Atlanta truck, about mid-53. I appreciate the leads. | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | I'll through out one other thought. I see you are converting to 12V. If you get the 6V harness, the wires will be large diameter because they carry more current. That's what I did and 'if' I ever convert to 12V, the 6V harness will work fine.
BTW, I used the classic harness for $150 with no issues. Good luck | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | I have date codes on my engine trans and rear from Nov 52 to Jan 53 and my truck has cloth insulated wires. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Oct 2013 Posts: 122 'Bolter | | 'Bolter Joined: Oct 2013 Posts: 122 | Last six digits on the VIN are 021143. Would this put my truck in that same era (late '52/early '53)? | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | Not to bring up an old thread, but I just purchased the $150 classic parts harness for my 54' w/ alternator. I have very little electrical knowledge, other than having installed a few sockets in the house, and some speakers/amps in an old car I had in highschool.
It took me a little while to get the harness oriented... I laid it out in the truck bed before trying to install it so I could get my bearings. Easiest thing for me to do, was pull out the headlight switch, and get that connected to the harness before anything... allows you to really see where the wires might be going for the rest of the truck.
Quality looks good, and I have only found any faults with it (which for those with more electrical experience it wouldn't be a problem). IF you're using a turn signal switch (such as the 7-wire from classicparts), you have to wire in your own flasher unit and fuse... but really that isn't all that terrible.
I'll be continuing to remove old wires, and install the new over the next week or so (hopefully I'll have time).
| | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | I am an electrical novice and was worse off 3 years ago when I did the install. No issues with my cheap harness aside from those customer service related. It took me about 6 hours to do. Wire by numbers is great and if I need to go back troubleshooting is really easy.
Me: Hi I just purchased a harness and I think it is missing fender grommets Phone Rep: We have been selling that harness for 20 years and no one has ever had a problem with that before Me: I'm sorry did I miss something? Phone Rep: If you really want that you need to buy the $24 dollar head light harness Me: wow great customs sevice!
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I just wired my '53 using $150 (cheap) harness from Chevs of 40s, possibly same as Classic Chevy, couldn't be easier. Got lots of help and hints on the Bolt, like ditching the plastic sockets (instrument lighting) and replaceing with originals. The plastic krap was just krap. Hardest part was intigrating my old turn signals.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Do the $150 wiring harnesses Classic Parts of America and Jim Carter now have plastic dash-bulb sockets? I have used at least 3 of their harnesses and they had metal dash/instrument-bulb sockets. | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | My harness has the plastic sockets (the 53-54 version) | | | | | Joined: Dec 2008 Posts: 901 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 901 | My 55.2 harness had plastic sockets also.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Tim, the Classic Parts harness looks to me to have plastic sockets, as does the currently shown ones at Carter, but the American Classic ones appear to be metal .... as I recall the 55-59 harness I got years ago has the plastic sockets Bill | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What's the chance that American Classic is using an old photo, and theirs are also plastic?
So sad.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | probably a good chance, but a call would find out .... I suspect the metal sockets have become obsolete or hard to reliably source so the wiring suppliers took the fast boat to China  does anyone have a source for new metal sockets? Bill | | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | My classic parts 55-59 v8 w/alt harness came with plastic light sockets as well.
Might be easy enough to trim off the new plastic ones replace with originals and crimp a new button end. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Rhode Island wire List the metal sockets Americal classic list a single wire socket Metal clip plastic body ...link... | | |
