| | | Forums66 Topics128,110 Posts1,056,255 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 239 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 239 | Starting looking for a truck in Arizona while taking a winter break in 2009. Missed out on a couple trucks. Back home in the winter of 2010 still looking. A friend kept finding and buying trucks and offered to find me a truck. Well in October 2010 I bought the '55 1st series. The truck is a rust free southern Idaho truck. The truck was all together but did no run and the brake peddle went to the floor. I started out working on the original engine and the brakes. Just wanted a driver. Replaced the brakes then concentrated getting it running. A friend had 261 engine from a 1962 two ton truck that needed rebuild. I also had a 1985 T5 transmission. The engine is now rebuilt, installed with the T5 transmission. Really a fun truck. Love the sound of the inline 6 with dual exhaust.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Nice. I'll bet its a fun truck to drive. | | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | You have a nice truck there. | | | | | Joined: Apr 2008 Posts: 239 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 239 | Just finished installing a rebuilt fresh air heater. Heater works great and has a valve for shutting off the heat, but it has been a hot summer here in Meridian Idaho. I want to install air conditioning in the truck. All that work rebuilding, powder coating and installing the heater may for not. New winter project is air conditiong system in the truck. | | | | | Joined: Apr 2008 Posts: 239 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 239 | Air conditioning system for the truck has been put on hold. On December 21st, the truck was put on a body shop for painting. The body shop guy does great work. He told me the truck will be finished in about 4 or 5 months. The time frame is ok with me as I'll have the truck back in the spring. He is a full time fireman in the local Idaho town, thus the stay in the shop will be an extended stay. All the chrome trim has been removed. The box, rear fenders and running boards have been removed. The door hinges have been rebuilt and the doors aligned. The saga for the painting process continues.
