| | | Forums66 Topics128,036 Posts1,055,460 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | After installing ,my lights I attempted to install the trim rings. My issue is that my seal looks different than some of the pictures I have seen. I searched and found an article from 2012. I only have one thin seal for each light, my question is does the seal go between the trim ring and the fender(large outer part of trim ring) or does it go between the light and the trim ring (smaller) inner part of the trim ring. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | the light goes in, then the trim piece that holds the bulb in.... and then the outer trim ring with the seal held in the outer trim ring with, I think, 4 clips.
If you've had damage repair on the front of the fender that outer trim ring can be a booger sometime.
| | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | thanks guys the picture shows that the seal is between the light and the ring, not the ring and the fender. So I will have to cut the seal to fit, it is too large that's why the confusion. i thought it went around the large outer ring !!?? | | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | stay tuned guys , this may go under electrical but the 3 wires from the head light : ground , high , low beam? | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Yes, ground, high, and low. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Maybe I'm reading your reply incorrectly, but the round rubber seal with the lip is in the rolled over edge of the molding (trim) ring and seals the gap between the molding and the retainer ring, it does not contact the headlamp at all: http://m7.i.pbase.com/g9/87/900387/2/154471417.H4Hk3he0.jpgDG
Denny G Sandwich, IL
| | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | yes sir just worded different | | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | does either of you know where I can get the protective cord looking stuff that is around the headlight wires? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | unless your shooting for some original looking stuff I'd buy some electrical shrink stuff and put it on the wires. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Try RI Wire or road island wire. After you look at their on line stuff call them. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | does either of you know where I can get the protective cord looking stuff that is around the headlight wires? Wire loom can be found at most auto parts stores. | | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | Ill shrink wrap the connections but like the look of the wrap after the shrink wrap. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | It's heat shrink, not shrink wrap. And are you talking about wire loom that you want it wrapped in afterwards? | | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | | | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | Yes, ground, high, and low. any diagram or info or does it matter which wire is which? no markings on the headlight wires, but my chassis wiring is labeled. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Yes, it definitely matters. What colors do you have on your pigtail? Usually there's white for ground, then two others, one high and one low. Should be black High Beam and Green Low Beam, but try it on a battery and see. I've seen red and green instead of black and green too. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Electrical questions should be asked and answered in Electrical Bay. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well I just spent an hour and a half composing an answer, I think we've satisfied the trim problem. The Low beam was a 16GA natural colored cloth wire with two green parallel tracers. The Hi beam was a 14GA natural colored cloth wire with two black crossed tracers. The ground was a 14GA plain natural colored cloth wire with no tracers. Here is the original wiring showing where on the socket they were located: http://www.pbase.com/dennygraham/image/138458355 And here are the new replacement wires about to be inserted in the socket: http://www.pbase.com/dennygraham/image/138459798Denny Graham Sandwich, IL
| | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | Thank you Sir!, and i will direct all my electrical questions to that forum (sorry). | | |
