3 members (RLB, Oswald, GRNHydra), 86 guests, and 2 robots.
Topics128,030
Posts1,055,430
Members48,422
#1006395 02/12/2014 12:00 AM
After installing ,my lights I attempted to install the trim rings. My issue is that my seal looks different than some of the pictures I have seen. I searched and found an article from 2012. I only have one thin seal for each light, my question is does the seal go between the trim ring and the fender(large outer part of trim ring) or does it go between the light and the trim ring (smaller) inner part of the trim ring.
the light goes in, then the trim piece that holds the bulb in.... and then the outer trim ring with the seal held in the outer trim ring with, I think, 4 clips.
If you've had damage repair on the front of the fender that outer trim ring can be a booger sometime.
Along with Alvin's description, these pix should answer most of
your headlight questions:
http://www.pbase.com/dennygraham/1950_headlight_&page=all
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
thanks guys the picture shows that the seal is between the light and the ring, not the ring and the fender. So I will have to cut the seal to fit, it is too large that's why the confusion. i thought it went around the large outer ring !!??
stay tuned guys , this may go under electrical but the 3 wires from the head light : ground , high , low beam?
Yes, ground, high, and low.
My 46 GMC on Photobucket
Maybe I'm reading your reply incorrectly, but the round rubber seal
with the lip is in the rolled over edge of the molding (trim)
ring and seals the gap between the molding and the retainer
ring, it does not contact the headlamp at all:
http://m7.i.pbase.com/g9/87/900387/2/154471417.H4Hk3he0.jpg
DG
Denny G
Sandwich, IL
yes sir just worded different
does either of you know where I can get the protective cord looking stuff that is around the headlight wires?
unless your shooting for some original looking stuff I'd buy some electrical shrink stuff and put it on the wires.
Try RI Wire or road island wire. After you look at their on line stuff call them.
Rhode Island Wire as GW posted, good people to deal with:
http://www.riwire.com/
I've used YnZ's before but their online catalog is very sketchy
since they changed it, the print catalog is more complete:
http://www.ynzyesterdaysparts.com/
Wiring Products.com has a complete line of asphalt coated wire loom:
http://www.wiringproducts.com/asphalt-coated-fabric-loom
Some of the vintage automotive vendors also carry it in a few different sizes:
http://www.classicparts.com/1941-87-Wire-Loom-3_8-ID-Foot/productinfo/52-956/#.UvyqmsuPLcc
DG
Denny G
Sandwich, IL
Wire loom can be found at most auto parts stores.
Ill shrink wrap the connections but like the look of the wrap after the shrink wrap.
It's heat shrink, not shrink wrap. And are you talking about wire loom that you want it wrapped in afterwards?
why yes
any diagram or info or does it matter which wire is which? no markings on the headlight wires, but my chassis wiring is labeled.
Denny G
Sandwich, IL
Yes, it definitely matters. What colors do you have on your pigtail? Usually there's white for ground, then two others, one high and one low. Should be black High Beam and Green Low Beam, but try it on a battery and see. I've seen red and green instead of black and green too.
Electrical questions should be asked and answered in Electrical Bay.
Well I just spent an hour and a half composing an answer, I think we've satisfied the trim problem.
The Low beam was a 16GA natural colored cloth wire with two green parallel tracers.
The Hi beam was a 14GA natural colored cloth wire with two black crossed tracers.
The ground was a 14GA plain natural colored cloth wire with no tracers.
Here is the original wiring showing where on the socket they were located:
http://www.pbase.com/dennygraham/image/138458355
And here are the new replacement wires about to be inserted in the socket:
http://www.pbase.com/dennygraham/image/138459798
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Thank you Sir!, and i will direct all my electrical questions to that forum (sorry).
