| | | Forums66 Topics128,090 Posts1,056,020 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#97860 05/14/2007 11:28 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | jon boy jonny,
I can see your address is on the other side of the pond. The markings on your regulator aren't the traditional items you would find on a stateside regulator. This doesn't mean it won't work though. Is your generator a Delco or unit made in the USA or is it something you have adapted to fit and are using a regulator compatible with it.
The third 'bobbin' that seems to be missing would be the cut-out relay. Did you have some paperwork that told you how to connect this regulator and indicated it would work with your generator. These things aren't hi-tech, but they don't work well when you just mix and match.
Stuart | | |
