Made an attempt at adjusting my steering today. I had the tie rod off because it was bent, so I did this with the driver's side wheel still connected and the front end on jack stands.
First I checked for freeplay in the worm gear and found none. I figured I'd back the adjustment screw out until I got a little play and then go back in the other direction until snug. But no matter how much I backed the adjustment screw out, I never got any freeplay. I assume this should be up and down play along the length of the steering shaft. I just put the screw back where it was originally, tightened the locknut and went to the sector gear.
There was a lot of freeplay here. When I grabbed the pittman arm and moved it, it would go back and forth. I removed all the play, tightened the lock nut, installed the repaired tie rod and put the front end back on the ground.
Result: Steering is way better than it was but I've still got loads of freeplay in the steering wheel. I'm sure not having a tie rod that's bent at a 30-degree angle helps, but the steering is still lousy. Should I do the adjustment with the wheels on the ground? I'll get under it tomorrow and have a friend move the steering wheel gently back and forth to see if something else is loose under there.
One thing I noticed is that I can grab the tie rod with my hand and roll it back and forth, like toward the front of the truck and toward the back. I'd guess it moves about 3/8 of an inch in either direction. The sockets in the tie rod ends are kind of ovalled, but I'm not sure if they were manufactured that way or if it's wear.
