There is about 4" (3 1/2" of spline) of shaft in the barrel of the slip-joint so there might be enough to cheat a couple inches forward and connect to the 420 since it's just that much shorter than to original SM465.
Any advice on how much spline contact in the barrel would be a minimum?
