...rather than pull it out to bleed make you up a couple short plastic lines and just turn the ends back into the reservoir. Its a lot simplier/easier than pulling it back out and you can keep and reuse the lines on something else..... I actually had some metal lines that I curved right back into the m/c.
Just and idea.
