Denny, if I remember correctly, mine weighed 1500 lbs. Two guys stood up each section, think they had just a small lift similar to an engine lift mounted on their flatbed. If your floor is only 4" thick, consider a toggle type anchor which you drive through the slab and then tighten up.
