buzn, I believe he is getting fuel to the carb and into the intake from what I read in his posts.I am not sure he is getting spark to the plugs yet,spark from the coil wire yes.
I am kind of curious now if the distributor gear has possibly sheared the roll-pin on the end of the shaft???(rare,but possible)
Boswell, does the rotor turn when you crank the engine?
There is enough good in the worst of us and enough bad in the best of us that it does not behoove any of us to criticize the rest of us.
Be yourself. If you are ever lost, It will be much easier to find yourself if you know who you are!
