Slip a bolt into the top of the tube- - - - - -I believe a 1/4" is about the right size. Then clamp a pair of vise grips over the area where the bolt is inserted and tap on the underside of grips with a hammer to slide it out of the block. Another way to do it is to slide a big socket over the tube before you insert the bolt, and use it like a slide hammer.
