Okay got it. Mine only has the one cotter pin hole on each end on both sides. On one side I went with the shorter spacer and on the other end I notif you looked through one end of the cotter pin hole to the other side it was nor perfectly aligned. So I enlarged thenhole slightly on one side and all is good!!!
