| | | Forums66 Topics128,100 Posts1,056,510 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2016 Posts: 114 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 114 | My problem is that I have been airdropped into the middle of a minefield, and I do not want to make a wrong step. Anywhere. How would I go about installing the modern air handler into an antique dashboard? I am okay with fabricating, but I do not want to spend several hours attempting to get it to "work." Would putting spark plug wires inside of stainless steel tubing cause any problems? And is the water pump issue a valid concern? Sorry if I am getting annoying with these questions, I just want to be sure of what I am doing. | | | |
Entire Thread
350 Chevy, How far should I go?
| Casey_58 | 12/10/2016 12:12 AM |
Re: 350 Chevy, How far should I go?
| Hotrod Lincoln | 12/10/2016 1:10 AM |
| Casey_58 | 12/10/2016 1:48 AM |
| Hotrod Lincoln | 12/10/2016 2:29 AM |
| Casey_58 | 12/10/2016 2:43 AM |
| Hotrod Lincoln | 12/10/2016 2:58 AM |
| Casey_58 | 12/10/2016 3:15 AM |
| Hotrod Lincoln | 12/10/2016 4:05 AM |
| Casey_58 | 12/10/2016 4:28 AM |
| Hotrod Lincoln | 12/10/2016 4:34 AM |
| Casey_58 | 12/10/2016 4:19 PM |
| CASO | 12/10/2016 8:39 PM |
| Justhorsenround | 12/10/2016 4:56 PM |
| Gord&Fran | 12/10/2016 11:47 PM |
| BC52 | 12/10/2016 9:52 PM |
| Hotrod Lincoln | 12/11/2016 12:13 AM |
| Flxible | 12/11/2016 1:53 AM |
| 52Carl | 12/11/2016 3:44 AM |
| Hotrod Lincoln | 12/11/2016 4:11 AM |
| 52Carl | 12/11/2016 11:56 PM |
| CASO | 12/12/2016 2:49 AM |
| yar | 12/13/2016 2:17 AM |
| carbking | 12/13/2016 4:49 AM |
| Hotrod Lincoln | 12/13/2016 5:34 AM |
| CASO | 12/13/2016 5:53 AM |
| Gord&Fran | 12/13/2016 6:04 AM |
| Hotrod Lincoln | 12/13/2016 4:52 PM |
| yar | 12/13/2016 11:12 PM |
| Hotrod Lincoln | 12/13/2016 11:21 PM |
| carbking | 12/14/2016 12:36 AM |
| tclederman | 12/14/2016 1:13 AM |
| yar | 12/14/2016 2:09 AM |
| carbking | 12/14/2016 5:15 AM |
| 52Carl | 12/14/2016 2:55 AM |
| Materman | 12/14/2016 4:02 AM |
| yar | 12/14/2016 6:08 AM |
| Hotrod Lincoln | 12/14/2016 3:26 AM |
| tclederman | 12/14/2016 3:46 AM |
| Hotrod Lincoln | 12/14/2016 4:59 AM |
| Justhorsenround | 12/14/2016 3:31 PM | |
