Well, thanks to Dave, lesson learned on the gasket set that you get from the machine shop. I will say this in the document too.
"Request a BEST Gasket set on your next rebuild. Pay extra, do NOT take no for an answer. Then, request that gasket set has a Rubber Rear Main Seal no. 4519S.
I will never make this mistake again.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
