Looks like my last reply didn't post
The main concern is the alignment of the cylinder with that of the brake pedal.
The pedal and the center of the cylinder should line up, but they're off by over an inch. Perhaps I need another frame mount as this one sticks out for the original brake cylinder but these dual cylinders are much wider preventing the two from lining up.
Thanks guys
Michael
