Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 64 guests, and 3 robots.
Topics128,009
Posts1,055,293
Members48,419
The 1947-early 49 door seals have a metal trim piece (3-actual pieces per side) that secures the weatherseal to the door frame is this reproduced anywhere?
That may be the same through 51 as mine has a metal trim that holds the weatherseal to the door as well. I believe that was discussed here some years back. You might check the archives. Also check the "parts for sale" forum here.
~Jim
It looks like Brad is referring to the " . . . metal trim piece (3-actual pieces per side) that secures the weatherseal to the door frame . . . " and those windlace retainers were used from 1947 through mid-1949.
The late 49 through 55-1st channels are available (they were/are spot-welded to the cab).
As BIG CHEVY 3600 suggested, your best bet is to place a Want Ad in the Swap Meet.
U
U Offline
classic parts has what your looking for. good luck putting it in better get some lube.
I think Brad is looking for the ones that screw on(47 to 50) instead of weld on. Eric
Moderated by  ndkid275, Phak1
