| | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | The 1947-early 49 door seals have a metal trim piece (3-actual pieces per side) that secures the weatherseal to the door frame is this reproduced anywhere? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | That may be the same through 51 as mine has a metal trim that holds the weatherseal to the door as well. I believe that was discussed here some years back. You might check the archives. Also check the "parts for sale" forum here.
~Jim
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | It looks like Brad is referring to the " . . . metal trim piece (3-actual pieces per side) that secures the weatherseal to the door frame . . . " and those windlace retainers were used from 1947 through mid-1949. The late 49 through 55-1st channels are available (they were/are spot-welded to the cab). As BIG CHEVY 3600 suggested, your best bet is to place a Want Ad in the Swap Meet. | | | | | Joined: Oct 2009 Posts: 35 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 35 | classic parts has what your looking for. good luck putting it in better get some lube. | | | | | Joined: Aug 2002 Posts: 154 'Bolter | | 'Bolter Joined: Aug 2002 Posts: 154 | I think Brad is looking for the ones that screw on(47 to 50) instead of weld on. Eric
