2 members (Gdads51, KEVINSKI), 81 guests, and 5 robots.
Topics128,259
Posts1,058,054
Members48,482
1957 235cui....
can I just put straight 87octane? or should I mix with lead-sub?
THANKS - John
As long as you're not pulling/hauling a heavy load, all day, everyday I wouldn't and don't use lead additives,
There's my opinion,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I do, its cheap enough and will not harm anything. I also use Marvel Mystery oil in the gas for top end lubrication always have. I have the same engine same year. Just my opinion. T/C Sjb
Pre 1975 engines were built for leaded gas. The heads did not have hard valve seats, and using unleaded will erode away the seats in a hurry. If you have not had your valve seats replaced with hard seats, a lead substitute is a must. Using a top oil like Marvel is fine for keeping carbon buildup on the stems. However we are addressing two totally different problems. Self serve came of age in the 70's, and a lot of people bought unleaded because it was 2cents higher than leaded regular they thought they were getting premium with tetraethyl lead. And it wasn't long before valve seats eroded to the point where the valves burned.
Just run 5% diesel fuel. (1 gallon diesel to 19 gal. gas) It will boost the octane as well as a lead substitute, and it's a lot less expensive.
You dont need it, unless as stated above, your working the motor extremely hard constantly or you plan on running a large amount of horsepower through the engine, in which case you probably have it torn apart and why not add hardened seats to the list?
Theres plenty of vehicles still on the road that were built with leaded gas in mind. If it makes you feel better it certainly couldnt hurt anything.
But after 55 years of abuse, I think my old 216 will speak for herself. She still runs great.
Jeff
My 1953 Chevrolet
1947.1 Gallery
Doesn't Diesel fuel have a much lower octane rating rating than gasoline?
Carburetion specialist
I do not use any of the lead additives; and have never encountered problems in any of my collector vehicles.
If/when it becomes necessary to rebuild an engine (for other reasons) we have hardened seats cut in the head. Permanent fix.
Jon.
The Carburetor Shop
I don't use it in any of my cars. Although they are not worked hard.
1949 Chevy 6400
1931 Chevy Firetruck
An old partsman tells me to put a cup of ATF with a fill up to improve seat life.
You Tube
Crenwelge....I was just pointing out that I also use Marvel Mystery oil along with "liquid lead". Some people do not realize that it will work in gas and or diesel. We have used both in tractors, cars, trucks, and stationary engines. I use "liquid lead" along with 89 octane in my 235. Its all a matter of personal choice, life is short if it makes you feel better then why not! T/C Steve
John,
This topic is almost as entertaining (and frequent) as the recurring discussions on engine colors and oil filtration alternatives.
As long as your are not heavily working your engine (very high revs, for very long periods) there does not seem to be a valve seat "erosion" problem on old low compression engines.
If you are rebuilding a head, you might want to consider putting in hardened seat inserts. Many of us have asked this same question and have left the head as-is with no problems (I asked 7 years ago).
Oh yes, the best advice is to take heed to carbking - he's a pro.
Tim
Diesel oil is not Octane rated it is Cetane rated.....how would that help valve seat life?
LEAD SUBSTITUTE is a safe and
effective valve seat protection additive which is
designed for use in engines which require the
protection of lead. Tetraethyl lead was originally
designed as an octane enhancer, but it was soon
discovered that the metallic oxides which result from
combustion form a protective coating on valves which
prevent microwelding of the valve seat to the valve
face under high temperature operation. This welding
of the two hot pieces of metal causes the removal of
the softer seat metal and subsequent recession of the
valve into the cylinder head. Wear debris then
contributes to valve stem and valve guide wear. Valve
recession causes poor sealing of the compression
gases, which means loss of power and fuel economy,
poor idle and driveability, and the eventual need for
cylinder head replacemen
