7 members (Uncles51, baldeagle, 1955 1 Series, 50Chevy3100, Gray_Ghost, Maybellene, Shaffer's1950),
121
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,026 Posts1,055,408 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 17 New Guy | | New Guy Joined: Jan 2014 Posts: 17 | just bought a 1949 6400. I was told it was a 216. engine block code starts with GEA. I read that this is a 235. any insight.
engine has bolts thru top of valve cover! | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | A 235 would have been stock. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | 235 is correct, this engine was manufactured and installed in the larger trucks under the name Loadmaster. The 216 equipped models went under the name Thriftmaster. More details on the engine and trucks is here: http://www.stovebolt.com/features/feature_stories/bigtrucks/index.htm | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2014 Posts: 17 New Guy | | New Guy Joined: Jan 2014 Posts: 17 | I noticed that in the big bolt review they mentioned that the 6000 series had a drive shaft emergency brake. My new 6400 has cables that go to the rear brakes. Is that typical?
thanks.
waiting to post pics once i get thru moderation.
thanks for all your help….If i want to change all fluids, what do you recommend? weight etc. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I have parted a couple 2-tons that had the cable actuated brakes so they could be configured that way. On the fluids you can just follow the manual recommendations these trucks do not need synthetics or anything to fancy. Owners manuals are available for your truck from a variety of the vendors for a reasonable price if you do not have one. | | |
