1 members (TexasA&M48Truck),
190
Mod | | | Forums66 Topics128,047 Posts1,055,532 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I think I know the answer, but I went out to install the door rubber, and I didn't know which way it went. SO...I looked it up and in the video I found the guy had the door off. I'm hoping I can leave the door on, but there isn't a lot of room. Has anyone done this with the doors in place and if so, did it work very well?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | thanks, I was hoping that's how it could be done. There certainly isn't a lot of room there. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | brokenhead,
There is no simple/easy why to do this. I have two trucks that will need this to be done on the doors. I did my Suburban with the doors off the body. I'll do my COE with the doors on the cab. After that, I'll figure out which technique requires fewer colorful words, and I'll use that technique on my pickup.
Alan's web page is quite helpful.
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Dealing with a mile long snake-like piece of rubber covered in sticky snot is hard enough to put on the door when it is on a bench, let alone trying to do it when its on the truck. I would take the door off and do it. You can't get enough practice uninstalling/reinstalling/adjusting doors to qualify as an expert at it. The problems with these @%#$&@ &*)*%$# (can you guess the words?)is you can't stretch them as you install them, and once it sticks , it is stuck. Doing it with the door on the truck has been a nightmare for me in the past. Carl
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I put mine on the panel while the doors were on..... but I won't anymore. It goes OK till you go down the front of the door by the hinges. To get it on good and to get it cleaned up afterwards I could have pulled 4 doors off and did it!!!
Mark your doors, if they fit good, and then take them off....I will the next time.....and if you replacing the worn out pins then that is the time to do it. | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | I did mine with the doors on and lots of masking tape to keep glue off the areas that I didn't want glue on. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I did mine with doors off. Afterward, the rubber let loose on the passenger door where it slightly rubs the outer body (ahead of door) during closing. Service manual calls this "wiping". Anyway, I pulled the door again to fix and glad I did instead of trying to re-glue with door installed. Only takes a few minutes to pull the door. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I built this support to fit on a floor jack. It was a fire grate that I bent a bit and welded a bar across. point is the cradle makes the whole process less stressfull. Thanks to MP&C for the idea! I only half apologize for the truck in the photo being OT because the back half is 56 GMC
