2 members (sron48, Gray_Ghost),
105
Mod | | | Forums66 Topics128,078 Posts1,056,052 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99590 02/28/2007 10:17 PM | Joined: Feb 2007 Posts: 4 Junior Member | | Junior Member Joined: Feb 2007 Posts: 4 | Hello, I am new to this forum and am building a 50 AD, I am to the point where I need to start making it streetable and would like recomendations on a 12v wiper system. Pictures of progress: http://s81.photobucket.com/albums/j214/CptKaos/ | | |
#99591 02/28/2007 11:01 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Kits are readily available & easy to install. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#99592 03/01/2007 12:35 AM | Joined: Feb 2007 Posts: 4 Junior Member | | Junior Member Joined: Feb 2007 Posts: 4 | Yes there are differant kits, I was hoping for a reply with recomendations, the quality can vary alot when ordering stuff online.
Larry | | |
#99593 03/01/2007 1:33 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | CptKaos,
Welcome to the Stovebolt. Another gentleman from the great state...there are lots on board.
Just to get you jump started a bit, you could go to the little search link at the top right of this page, and put in electric wiper . This will give you some ideas before more folks see this topic and chime in.
Stuart | | |
#99594 03/01/2007 1:50 AM | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | Welcome to the site,CptKaos.I installed a "Newport Electric"wiper in my truck.It just about installed itself.Two speed self park.About $180us | | |
#99595 03/02/2007 3:25 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I have also used the New Port unit. It has worked flawlessly for the last 5 years now. I hereby recommend it! Shop around though, prices vary quite a bit between the different vendors, Scott | | |
#99596 03/02/2007 4:20 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | cptkaos,I just installed the newport wiper motor this evening.I cussed it,only because i was laying in some awkward positions.It bolted in just fine.It came with a support bracket that mounted to the cross brace on the dash.It actually is designed to bolt where a factory clip is located.The factory clip holds the temperature cable.I just relocated the temp line clip.I'm going to make a bracket to hold the wiper switch on the bottom edge of the dash.The switch was going to be too tight of a fit under the dash against the wiper motor.I like my factory chrome switch,so decided to leave it in the dash.The newport wiper motor calls for upto 10amp fuse in an fuseable link.You can get it at any parts store.The wipers work great,they are two speed with park in the off position.I called my local 47-53 parts supplier and asked if they would match the Truck Shops price, They beat it by $3.00 .I would deffinetly reccomend the newport wiper motor ,it runs smoof . 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#99597 03/02/2007 4:58 AM | Joined: Feb 2007 Posts: 4 Junior Member | | Junior Member Joined: Feb 2007 Posts: 4 | thanx everybody, I am now searching for a supplier. I hope to have her on the road in another week or 2
Larry | | |
#99598 03/02/2007 5:29 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Another tip, remove the speaker grille in the dash.You can gain some access through it.It will help you tremendously !!! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#99599 03/03/2007 12:29 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Bc52,the purple 52 you have in the gallery,is the electric wiper motor installed in this picture.My wiper arms are parking in the same position with my newport motor.I am hoping to get them to park more parallel to the windshield molding.The newport motor runs smoooooff !!!! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#99600 03/03/2007 2:01 AM | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | bowtietim,no the newport was not installed yet.When I got the truck the single speed motor did not self park.I would shut it off close as can then push them down when I got out.With the newport the arms park better but not equal.There is some play in the linkage. | | |
#99601 03/03/2007 4:28 AM | Joined: May 2006 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 102 | I got mine from LMC Truck for $140. I also bought the wiper delay switch they offer for $55. I haven't installed mine yet. Your truck looks great. Welcome to the stovebolt.
All the best, Ted
#99602 03/03/2007 7:03 PM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Ted, who makes the wiper motors that lmc sells. I looked at them,the brackets look a little different than the newport i bought. Just curious !! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#99603 03/04/2007 11:34 PM | Joined: May 2006 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 102 | Bowtietim, Sorry I don't know, there is no indication as to manufacturor, a marketing secret no doubt. The motor does look well made, all steel, and is good and heavy. LMC's installation instructions say on the bottom that they are a reprint from the manufacturor's instructions. If any one has used them please chime in. I will installing mine shortly.
All the best, Ted
#99604 03/05/2007 3:12 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Ted, good luck and let us know how the lmc wiper motor works.I paid $22.00 more for the newport.It works great so far,but i have'nt used it yet"really used it".It will help taking the dash speaker grille trim off,you will gain access through the dash.
Good luck,Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#99605 03/07/2007 7:32 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I installed the LMC 6v/12v wiper a little while ago and had to make one of the arms adjustable. The problem was probably "me." I opened the case and this motor has a big plastic gear. I think others are all metal. I've had no problems with it. For the previous post and a link to a picture, check: Previous post on the 6v/12v LMC wiper motor 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
