8 members (tclederman, Hotrod Lincoln, ChevyBlue, moparguy, mk72, farmallb, Opelika Tom, Otto Skorzeny), 179 guests, and 1 robot.
Topics128,089
Posts1,055,988
Members48,430
#99590 02/28/2007 10:17 PM
Junior Member
Junior Member
Hello, I am new to this forum and am building a 50 AD, I am to the point where I need to start making it streetable and would like recomendations on a 12v wiper system.
Pictures of progress: http://s81.photobucket.com/albums/j214/CptKaos/
#99591 02/28/2007 11:01 PM
Riding in the Passing Lane
Kits are readily available & easy to install.
1972 Chevy c10 Cheyenne Super
#99592 03/01/2007 12:35 AM
Junior Member
Junior Member
Yes there are differant kits, I was hoping for a reply with recomendations, the quality can vary alot when ordering stuff online.
Larry
#99593 03/01/2007 1:33 AM
CptKaos,
Welcome to the Stovebolt. Another gentleman from the great state...there are lots on board.
Just to get you jump started a bit, you could go to the little search link at the top right of this page, and put in electric wiper . This will give you some ideas before more folks see this topic and chime in.
Stuart
#99594 03/01/2007 1:50 AM
Welcome to the site,CptKaos.I installed a "Newport Electric"wiper in my truck.It just about installed itself.Two speed self park.About $180us
#99595 03/02/2007 3:25 AM
I have also used the New Port unit. It has worked flawlessly for the last 5 years now. I hereby recommend it! Shop around though, prices vary quite a bit between the different vendors,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#99596 03/02/2007 4:20 AM
cptkaos,I just installed the newport wiper motor this evening.I cussed it,only because i was laying in some awkward positions.It bolted in just fine.It came with a support bracket that mounted to the cross brace on the dash.It actually is designed to bolt where a factory clip is located.The factory clip holds the temperature cable.I just relocated the temp line clip.I'm going to make a bracket to hold the wiper switch on the bottom edge of the dash.The switch was going to be too tight of a fit under the dash against the wiper motor.I like my factory chrome switch,so decided to leave it in the dash.The newport wiper motor calls for upto 10amp fuse in an fuseable link.You can get it at any parts store.The wipers work great,they are two speed with park in the off position.I called my local 47-53 parts supplier and asked if they would match the Truck Shops price, They beat it by $3.00 .I would deffinetly reccomend the newport wiper motor ,it runs smoof .
1951 3100 Chevrolet
#99597 03/02/2007 4:58 AM
Junior Member
Junior Member
thanx everybody, I am now searching for a supplier. I hope to have her on the road in another week or 2
Larry
#99598 03/02/2007 5:29 AM
Another tip, remove the speaker grille in the dash.You can gain some access through it.It will help you tremendously !!!
1951 3100 Chevrolet
#99599 03/03/2007 12:29 AM
Bc52,the purple 52 you have in the gallery,is the electric wiper motor installed in this picture.My wiper arms are parking in the same position with my newport motor.I am hoping to get them to park more parallel to the windshield molding.The newport motor runs smoooooff !!!!
1951 3100 Chevrolet
#99600 03/03/2007 2:01 AM
bowtietim,no the newport was not installed yet.When I got the truck the single speed motor did not self park.I would shut it off close as can then push them down when I got out.With the newport the arms park better but not equal.There is some play in the linkage.
#99601 03/03/2007 4:28 AM
I got mine from LMC Truck for $140. I also bought the wiper delay switch they offer for $55.
I haven't installed mine yet. Your truck looks great. Welcome to the stovebolt.
All the best, Ted
#99602 03/03/2007 7:03 PM
Ted, who makes the wiper motors that lmc sells. I looked at them,the brackets look a little different than the newport i bought. Just curious !!
1951 3100 Chevrolet
#99603 03/04/2007 11:34 PM
Bowtietim,
Sorry I don't know, there is no indication as to manufacturor, a marketing secret no doubt. The motor does look well made, all steel, and is good and heavy. LMC's installation instructions say on the bottom that they are a reprint from the manufacturor's instructions. If any one has used them please chime in. I will installing mine shortly.
All the best, Ted
#99604 03/05/2007 3:12 AM
Ted, good luck and let us know how the lmc wiper motor works.I paid $22.00 more for the newport.It works great so far,but i have'nt used it yet"really used it".It will help taking the dash speaker grille trim off,you will gain access through the dash.
Good luck,Tim
1951 3100 Chevrolet
#99605 03/07/2007 7:32 PM
I installed the LMC 6v/12v wiper a little while ago and had to make one of the arms adjustable. The problem was probably "me." I opened the case and this motor has a big plastic gear. I think others are all metal. I've had no problems with it.
For the previous post and a link to a picture, check:
Previous post on the 6v/12v LMC wiper motor
