1 members (JW51), 96 guests, and 0 robots.
Topics128,050
Posts1,055,643
#993608 12/19/2013 5:42 PM
I'm looking for a recommended vendor for a '42 1/2 ton grille. Not sure of the quality from the different vendors. What is the quality of the chrome or should I buy it bare and have it plated myself?
gerrys42 #993701 12/20/2013 3:33 AM
Gerry, its always better to go with original metal if you can. It may be a little more challenging to get it worked out but it'll beat the after market ones. I SUSPECT that most all aftermarket ones come from the same place!
Isn't there a place in Cherryville,N.C. that still does chrome plating the way its suppose to be done?!
I purchased a new re-pop grille for my 52panel. Its decent but the plating is not very "thick". About all they do is flash chrome it with little thought to thickness or hardness. In the "creases/recesses" of a cheap grille you will find what looks to be "dust particles" chromed over.
If you plan to keep your truck inside and waxed up a re-pop would probably be cheaper and last fairly well. This is all just my opinion/.02 cent. Good luck.
gerrys42 #993778 12/20/2013 2:21 PM
Gerry,
Your question should be where can I get one. The manufacter that was making the grills has stopped because of very bad quality problems. Finding a vendor that has one and is willing to sell it will not be easy. I'm told the new tooling is still about 6 months to a year away. The last re-chromed original one I saw on sleezbay went for north of $1500. good luck
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
gerrys42 #993798 12/20/2013 4:05 PM
Have to second the caution above. I did similar homework regarding the re-pops and never found anyone who was happy with what they got. Horrible fit, cheesy chrome and nearly all from China. Mine had a straight grill so I sprang for a "95-point" chrome job locally. They could have done a 100-point but for a driver, what I came home with was beautiful. Cost me a grand but I'm not complaining. My 2 cents.
1946 1.5-Ton Chevy Shorty Bus
All my best --- Tango
Tango #993810 12/20/2013 5:16 PM
Crusing in the Passing Lane
There was not chrome for grills, etc., during the war, green paint. I have one of those(GMC.)
gerrys42 #993849 12/20/2013 10:13 PM
Grey paint you mean? That was standard for 42 and 45 trucks.
My 46 GMC on Photobucket
gerrys42 #994036 12/21/2013 8:39 PM
'46's had either chrome or polished stainless. If you can score a stainless version, they can't be beat for my money. No rust and they polish out almost as bright as the best chrome. Good luck.
BTW...all are interchangeable from 1/2 thru 2 ton except for the COE's.
gerrys42 #994206 12/22/2013 6:36 PM
my 46 1/2 ton has a chrome grill
gerrys42 #994400 12/23/2013 7:02 PM
My '46 was chrome as well, but some other parts were stainless.
