1 members (Steelonsteel),
44
Mod | | | Forums66 Topics128,090 Posts1,056,024 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 178 Shop Shark | | Shop Shark Joined: Dec 2013 Posts: 178 | Can anyone tell me what steel Chevy rally style wheels will fit the old girl (if any)? If not what should I use for a quick way to get her rolling off the storage lot where she sits now on the split rims?? I want to get the truck home, but don't want to choose her ultimate wheels just yet. Thanks from a new 47 owner.
Have you ever noticed that anyone driving slower than you is an idiot and anyone driving faster than you is a maniac? - George Carlin
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | 90's vintage Ford and Chevy 8-lugs will bolt right up on the back. The front is a bit more problematic as they will not clear the tie-rod ends. There are some trailer wheels that people have used here you can source as well. Do a search here on the topic and you should get some insight into those options. Since these are just temp wheels you can perhaps shop for the best deal. I got mine off a 91 Suburban from a wrecking yard for $80 for a set of four. I built my own steering arm and tie-rod for clearance. I then modified them to accept original caps. http://www.flickr.com/photos/advance-design_parts_co/8129054429/in/set-72157631867396207 | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Here's a link to another post. https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=994319#Post994319I have Ford rims on my 54. No clearance issues. It's tight though. I doubt you could even get a wheel weight on the inside of the rim without hitting the tie rod. There's a handful of members that have used Dexstar trailer rims with good luck.
