6 members (Woogeroo, sparky46, Otto Skorzeny, lumbersawyer, LAROKE, Gdads51), 141 guests, and 1 robot.
Topics128,104
Posts1,056,201
Members48,436
#994217 12/22/2013 7:40 PM
Yesterday I found and arranged to buy at a later day after the Christmas holiday some extra parts left over after his '48 project was completed. In this pile of pieces are stainless window trim, rear bumper, other misc. 1/2 ton Chrome plated grill, 2- doors and a grill from a 3/4 ton (I was told this).
The thing I noticed the primary grill bars for the 3/4 are 1/4" or 3/8" taller then the grill bars for a 1/2 ton truck. I thought that 1/2 and 3/4 ton are the same. Help me out on this issue.
So are the 1/2 and 3/4 ton truck doors the same?
As a side note, the Chrome grill has some slight damage. I believe I can remove this dent. What I don't know at this time, will the Chrome plating survive ?
Woodildo
I would have bet even the grill was the same?47-53 are a lot like old Harleys and inter change so easy.Maybe the years of grills are not just alike and its been interchanged?I like wing glass to use a lot and like the 51-55 better just for that and would have got a pair if cost the same if had to replace a 47-50.Guess if this comes up better check into this more.Sure lots on here will know for sure.
I don't know about GM, but the "chrome" on my 47 Mercury was actually stainless steel. The man who bought it from me after I'd owned it for 13 years straightened all the little dings out of the trim and re-polished it like brand new. No plating involved at all!
The 47-51 and 54/55 Advance-Design chromed grills were chrome (none were stainless steel).
The "bright" window surrounds were stainless steel in years that had them for inside/outside door-windows, windshields, and panel/suburban rear door windows.
If the grill is that much bigger my guess it is from a 1-1/2 ton or bigger truck since that is about the difference in size. 3/4-ton grills are the same as the 1/2-ton.
Those bright surrounds polish up like new and really set off a truck cab in my opinion.
http://www.flickr.com/photos/advance-design_parts_co/8129179541/in/set-72157631867396207
I called and talk to the seller and he said after some thought, some parts were from a dump truck. So it must be that the taller grill bars are from a Big Bolt.
Woodildo
