5 members (Steelonsteel, Tyler Watts, RaNfLaS, rfs56trk, DadsFirstPickup), 101 guests, and 2 robots.
Topics128,048
Posts1,055,663
#99309 02/19/2007 1:20 AM
in order for the ammeter to work correctly I am assuming the wire from battery/solenoid goes to "charge" side of ammeter and alternator connects to "discharge" side. Is this correct???
'58 3600 350/4-sp/stepside/big window cab
'59 3100 235/4-sp/stepside
I'm unsure of your terms but will try to help. The following is for a negitive ground system.
1. The ampmeter NEVER goes between the starter and battery.
2. The (+) side of the ampmeter goes to battery solenoid/battery.
3. The (-) side of the ampmeter goes to the (BATT.) post on your altenator and some accessories like horn relay and light switch.
Hope this helps.
thanks beltfed, this is exactly what I needed.
Riding in the Passing Lane
If you get it backwards it will just work opposite of the way it should & turn the connections around.
1972 Chevy c10 Cheyenne Super
thanks for all the help guys. got everything straightened out, all rewired and working like it should.
Carl
be sure,
since you ARE using the amp meter that you use rubber covers on the bolts that stick out behind the dash.
anything that touches those bolts will cause a BIG spark :confused: .
me, I'd get a volt meter
my .02
Jim & Caroline
