| | | Forums66 Topics128,051 Posts1,055,768 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99309 02/19/2007 1:20 AM | Joined: Oct 2006 Posts: 125 Member | | Member Joined: Oct 2006 Posts: 125 | in order for the ammeter to work correctly I am assuming the wire from battery/solenoid goes to "charge" side of ammeter and alternator connects to "discharge" side. Is this correct???
'58 3600 350/4-sp/stepside/big window cab '59 3100 235/4-sp/stepside
#99310 02/19/2007 3:38 AM | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I'm unsure of your terms but will try to help. The following is for a negitive ground system. 1. The ampmeter NEVER goes between the starter and battery. 2. The (+) side of the ampmeter goes to battery solenoid/battery. 3. The (-) side of the ampmeter goes to the (BATT.) post on your altenator and some accessories like horn relay and light switch. Hope this helps.
#99311 02/19/2007 5:32 AM | Joined: Oct 2006 Posts: 125 Member | | Member Joined: Oct 2006 Posts: 125 | thanks beltfed, this is exactly what I needed.
#99312 02/19/2007 10:42 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you get it backwards it will just work opposite of the way it should & turn the connections around. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#99313 02/20/2007 3:30 PM | Joined: Oct 2006 Posts: 125 Member | | Member Joined: Oct 2006 Posts: 125 | thanks for all the help guys. got everything straightened out, all rewired and working like it should.
Carl
#99314 02/20/2007 3:43 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | be sure, since you ARE using the amp meter that you use rubber covers on the bolts that stick out behind the dash. anything that touches those bolts will cause a BIG spark :confused: .
me, I'd get a volt meter my .02
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
