Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (baldeagle), 43 guests, and 0 robots.
Topics128,003
Posts1,055,244
Members48,418
#990341 12/03/2013 11:34 PM
I am working on a1965 gmc that had a v-6 in it have changed over to 350 small block my ignition switch has 4 prongs the marking on the prongs are as follow
BAt
ING
ACC
D-R
using a ohm meter when I turn the key to 1st postion all 4 prongs I get a reading when I move the key to what I thing is the start the ING prong drops out and I get no ohm reading on it but I do get a reading on the other prongs which wire should I use for the start selnoid for the started is there any where I can get a wiring digrham
Bob May
D-R appears to be for bypassing the ballast resistor. I have never seen one marked that way. They are usually marked IGN1 and IGN2. The terminal that is hot in 'run' position goes to the ballast resistor. The one hot in 'start' bypasses the resistor.
If you have an internal resistor coil, jumper the terminals.
thanks for your help
Bob May
