| | | Forums66 Topics128,005 Posts1,055,261 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 59 | I am working on a1965 gmc that had a v-6 in it have changed over to 350 small block my ignition switch has 4 prongs the marking on the prongs are as follow BAt ING ACC D-R using a ohm meter when I turn the key to 1st postion all 4 prongs I get a reading when I move the key to what I thing is the start the ING prong drops out and I get no ohm reading on it but I do get a reading on the other prongs which wire should I use for the start selnoid for the started is there any where I can get a wiring digrham
Bob May
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | D-R appears to be for bypassing the ballast resistor. I have never seen one marked that way. They are usually marked IGN1 and IGN2. The terminal that is hot in 'run' position goes to the ballast resistor. The one hot in 'start' bypasses the resistor.
If you have an internal resistor coil, jumper the terminals. | | | | | Joined: Aug 2013 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 59 |
Bob May
