4 members (Gray_Ghost, IHPWR, Rusty Heaps, FAST55), 61 guests, and 3 robots.
Topics128,026
Posts1,055,404
Members48,422
#98819 01/09/2007 2:08 AM
I just bought a spotlight off ebay and it is in pretty good shape. I have a 6/12v battery charger and used it to test the bulb. The bulb lit up, just not very bright. I tried to test it in the spotlight with the switch. I attached the spotlight wires to the bulb and then attached the charger to the lead wire: black wire to the lead wire and red I just touched to the light assembly for the ground. I flipped the switch and nothing happened. Am I testing it right? If I am, is it probably the switch? or something along the way? Where does the power go through from the handle to the head? maybe that point is rusty or something? Any ideas please...
thanks
#98820 01/10/2007 2:00 AM
Z
Z Offline
the charger may not had enough amperage for a spot light.try hooking it to a battery.
#98821 01/10/2007 2:38 AM
Could be corrosion/dirt on the switch itself inside thats not making contact. Or even the contacts that touch the bulb? Havent had my spotlight apart yet.
Good luck. Jeff
My 1953 Chevrolet
1947.1 Gallery
#98822 01/10/2007 3:03 AM
It will take more AMPS to run the light at it's full brightness.Could be 30 AMP circuit.
#98823 01/15/2007 4:56 AM
Ditto on amps. It's a charger, not a battery.
