0 members (),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#98819 01/09/2007 2:08 AM | Joined: Nov 2006 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 125 | I just bought a spotlight off ebay and it is in pretty good shape. I have a 6/12v battery charger and used it to test the bulb. The bulb lit up, just not very bright. I tried to test it in the spotlight with the switch. I attached the spotlight wires to the bulb and then attached the charger to the lead wire: black wire to the lead wire and red I just touched to the light assembly for the ground. I flipped the switch and nothing happened. Am I testing it right? If I am, is it probably the switch? or something along the way? Where does the power go through from the handle to the head? maybe that point is rusty or something? Any ideas please... thanks | | |
#98820 01/10/2007 2:00 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | the charger may not had enough amperage for a spot light.try hooking it to a battery. | | |
#98821 01/10/2007 2:38 AM | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Could be corrosion/dirt on the switch itself inside thats not making contact. Or even the contacts that touch the bulb? Havent had my spotlight apart yet.
Good luck. Jeff | | |
#98822 01/10/2007 3:03 AM | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | It will take more AMPS to run the light at it's full brightness.Could be 30 AMP circuit. | | |
#98823 01/15/2007 4:56 AM | Joined: Jul 2006 Posts: 187 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 187 | Ditto on amps. It's a charger, not a battery. | | |
