6 members (tclederman, Peggy M, MRMEROTH11, Wickedbass, Barney1951, TUTS 59), 78 guests, and 1 robot.
Topics128,068
Posts1,055,880
Members48,428
#987012 11/18/2013 4:28 PM
want to join the old dominion stove bolt society once i get this bolt running again just purchased it for scrap price but i am a mechanic and as long as i can get the parts it will live again but i ran into the "huck" brake issue the rear drums were seized and are pitted beyond repair one had to be shattered before i could even get it off. i just need the cheapest solution and i hope someone has some info on where to get parts or hopefully some good used parts.. thanks all for any advice or help.
62401
You don't have to wait until your truck is running -- you can join in on the fun any ole time!
Check the "Links" link in the menu var at the top of the page and look under "Parts." Most of the major parts suppliers carry all the brake parts you need (American Classic, Jim Carter, Kanter, etc). I recently goot wheel cylinders for my '49 1-ton no problem.
What is your truck and where in VA are you? We have pretty good covereage in central and northern VA. A little sparse in Norfolk/VA Beach area or DeMarVa.
Welcome aboard!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
yeah been checking those sites and i can find everything except the drums still no luck on them yet but hopefuly soon just want a good used set. easiest way to put where i am is where the rappahanock river meets the bay in a small town called White Stone. I have a 52 gmc 3/4 ton that was parked in 1984 has some cancer but i know i can get it going all original and everything is working so far except the brake systems. i also have a 49 chevy 3/4 ton 5 window but it is in worse shape the frame is rusted out for starters and the rear brakes are seized bad on it too i had to shatter one drum on the gmc and im sure i will have the same problems on the chevy so i dont even want to try. i would like to attend one of your events in virginia dont know if you ever have any in richmond or fredericksburg but im only an hour and a half from those two cities. thanks and look forward to meeting you guys.
ODSS Lawman
ODSS Lawman
Welcome!!
I live in Fredericksburg along with several other ODSS members in the surrounding areas.
Looking forward to meeting you!
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
ODSS President
ODSS President
Welcome! Cosmo here in Charlottesville.
~ Cosmo
1949 Chevy Half Ton
Greetings,
Jim here in Bowling Green, VA. Not too far. My truck came to me as a basket case. It's now got body panels (although rotted) on it and I am in the "shake down" phase before considering painting it.
Welcome aboard.
Jim
1957 Chevrolet 3100 Stepside
235, 3-speed w/OD
ODSS President
ODSS President
Huck rears are different from the fronts, NOT interchangeable at least for a 1/2 ton.
Plenty of good reading here...
We are doing a winter (in January) junk yard tour and the place we're going to does have some AD trucks, they are 1/2 tons so find out if the drums are the same. Wait, if you're 3/4 ton that's 8 lug, right?
regards,
Cosmo
~ Cosmo
1949 Chevy Half Ton
Moderated
Moderated
I'd like to jump on this band wagon also If I may... just got me a 53 Chevrolet 3100 last week and I'm pretty much starting from square one when it comes down to auto knowledge. If there are any guys down in Va Beach who link up every once in a while and talk trucks then I'd love to join in and learn the ropes. -Jason
Welcome to the group Jason wave
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Aw, man... I live about 10 miles from you- about 2-3 years ago I replaced my 3/4 ton axles with a 1/2 ton front axle and S-10 rear so I could get disc brakes. I gave away the axles and huck brakes, which all worked fine. I gave away the 8 lug wheels and tires, too. I'd rather see someone bring an old truck back to life than try to sell them. Sure wish I had waited, or you had needed them sooner. Best of luck, and hope to see you around the northern neck area sometime.
Also- I lived in Bowling Green from '91-2000, then F'burg from 2000 till '05. Lots of bolters in the area.
Bluesharp- If you don't blow you suck....
'50 Chevy 3600 "Ernest"
Hi Ogrady. I have not heard the term "huck" yet. But I am aware of some folks using brake parts (drums and backing plates) from a 14 bolt on the H052 and H072 rears. Might want to check that out.
darn missed out on a few good deals... oh well did find a damaged frame with all my brake parts going to get it early December so hopefully I will be driving her around shortly after... got the engine running good just on seperate fuel system.. bits and pieces she is getting there. Just gutted the interior sanded and am painting flat black.. she's coming along
welcome, I am in woodbridge, VA
I just removed everything off my 49 3/4 ton. I only retained the frame. I have all parts from it that you are more then welcome to. I live near Laplata Maryland.
Moderated by  Bill Marlow, SWEET
