9 members (Oswald, Bill Hanlon, Rosco, Southerntruck, Bungeemaster, 2-Ton, Pre '68 Dave, TUTS 59, 1 invisible),
253
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,288 Posts1,058,566 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 18 New Guy | | New Guy Joined: Aug 2011 Posts: 18 | Repaired shift linkage and replaced hose clamp on heater hose. | | | | | Joined: Feb 2003 Posts: 1,391 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,391 | Staring the rebuild of a Carter YF to replace the Rochester. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Got the last bits needed to install my fresh air heater and fender support rods tomorrow. | | | | | Joined: Nov 2013 Posts: 79 'Bolter | | 'Bolter Joined: Nov 2013 Posts: 79 | great pictures and what a lot of work. I may have some heater questions for you when my 51 gets here. correct me if I'm wrong but I thought 1951 was a chrome delete.
1952 Chevy 3100 1953 chevy 3100 Hot Rod 1946 Chevy Pickup
| | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | jim, I'm not positive but I think 52/53 were the ones with no chrome. (Korean war) | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | got a new cab corner in today | | | | | Joined: Nov 2013 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2013 Posts: 73 | Well I got my carb parts and fuel pump yesterday and put them on-primed it one more time to save the starter and fired it up. sure runs better with a clean carb,fresh fuel and cleaned and gapped plugs. the old 305 sounds good. long way to go before it's ready to get an inspection sticker on and drive on the road but got new brake drums and shoes coming in today.getting it where it will stop could be important. one thing I haven't located that I need is a front wheel hub cap. on my 61 GMC 1000 I measured about 2.075" I.D. on it. there is an original on one side but missing the right one.I wonder if the local GM dealer might actually be able to get me one? | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Dealers and parts people only know VIN info, so, take that with you, probably won't have one, anyway. Put on your parts scrounging list.
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Started on the '41 project and I have been meaning to make some posts, but have been just so busy. Anyway I've got it all stripped down to the frame. The next step is channeling the front frame and adding the IFS. Here's the progress so far.... http://s783.photobucket.com/user/johntsmith1056/slideshow/41%20chevy%20project
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Keep the updates coming John.
~Jim
| | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | Finished up the Passenger side Cab corner today! | | | | | Joined: Dec 2012 Posts: 72 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 72 | Finally got the windshield and back glass in! http://www.flickr.com/photos/ajporsche/10955278574/I got the stainless surround trim from a fellow Bolter here, Neil, and it just looks awesome. I'm going to take it out on the main roads this weekend. It'll be it's first real drive on the road in over 15 years. I think I'm ready, just worried something will go wrong. I've spent all this time working on this thing, and have never really driven it. I'm sure it'll be fun, wish me luck! | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Built a "Runtz" voltage regulator for the fuel gauge. Total cost about $2.50 | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Feb 2003 Posts: 1,391 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,391 | Worked on the front springs,when I took them apart to clean them up and put in teflon I never put the clamps back on so they went on today. The tube shocks were rubbing so I need to add some spacers behind the brackets so that is tomorrows job and then on the replacing the master cylinder. | | | | | Joined: Feb 2012 Posts: 60 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 60 | Just spent 25 hours on truck over last 3 days. Wrapped up work for the year as it is too cold in garage now. This year replaced the bulk of sheetmetal work, cab corners, cowls, floor, .... next april back onto lower door patch,... uploaded new pics
1951 Chevy 3100 | | | | | Joined: Feb 2003 Posts: 1,391 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,391 | Found the rattle,it was a loose shock bracket. I bought the conversion kit from Jim Carters and it was not really designed for a 37 and the shocks were too long so I made brackets to extend the brackets so I am going to see if I can find shorter shocks. | | | | | Joined: Feb 2003 Posts: 1,391 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,391 | Took it for a test drive today and the loose bracket was definately the source of the rattle,I removed the floor so I can replace the master cylinder and while I have the floor out I will also replace the battery since its almost 6 years old. | | | | | Joined: Feb 2003 Posts: 1,391 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,391 | Got the new master cylinder in the 37 tonight and was going to take the battery out of another vehicle so I could install the floor and call the 37 done but the battery was too big,so now I am going to price a new battery for the 37. When I installed the T-5 I had to make the battery box smaller and could only use a group 51 battery which is for a Honda Civic,even a decent battery at the parts stores are around a hundred so I think I can get one from Rural king for a little less so it will be this weekend before I will finish the 37. | | | | | Joined: Oct 2005 Posts: 4,263 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,263 | Installed a new fuel sender. Gauge problem solved. Tried to see what I could do about the lousy drivers door aftermarket latch. No go. Repaired the bad ground in the left rear turn signal. Installed the gasket properly in the cowl vent. Hopefully no more leaks. | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | removed the beat up and rusted angle strip on one bed side... that was a royal pain. | | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | finally got my Unity S6 Spotlight installed. Step 1 Step 2 Step 3 assembled and it works.
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | Mike, glad you shed some LIGHT on the subject  Thanks for sharing. | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 |
| | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | David, John, nice work guys. I like it! | | | | | Joined: Oct 2005 Posts: 4,263 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,263 | Agreed! Nice work, guys!! | | | | | Joined: Feb 2013 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2013 Posts: 52 | Over the Thanksgiving weekend my son and I went out to the farm and washed and packed up all the pieces/parts for the 1950 3100 hot rod project. We got it ready to haul home in the spring to begin work on it. The 1974 4 bolt main 350 still turns easily by hand (been sitting in the building for 17 years waiting). It is a hot rod project I picked up in 95 and never really did anything with. It will be fun to build it with my son, it already had a 69 camaro subframe welded in when I got it so there is no concern to keep it original. My son and I will be able to go wild modifying this thing without having to feel bad  . We will keep the 50 panel and the old 49 3/4 ton all original when this one is done. When I put it on the trailer and pull it down in the spring I will take some pictures. Did not have time over the weekend. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Sounds like a plan Chris. We'll be looking forward to the pics.
~Jim
| | | | | Joined: Sep 2011 Posts: 116 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 116 | I had not drove the gmc since last Sunday, so at lunchtime yesterday, with the temperature at -3, and about 6 inches of snow on it, I attempted to start her up. No problems, had a lot of looks while I went for a drive around town. Lots of folks having trouble with our first taste of cold. 1955 Second Series GMC"Done - A 50 Year Journey"Follow in the DITY-- No one said it was going to be easy
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Removed the angle strip on one side of the bed. Did the other yesterday. Have to agree with GMJagger that it is a pain. On the first one I hand sanded the strip since there were a couple of old coats of paint and hard to tell where the spot welds were. On the one today I used one of those plastic type stripping wheels with the drill. That worked well because in addition to being able to feel the dimple since most of the paint was taken off, but it didn't remove all the paint in the dimple. Kind of like spraying a guide coat when doing body work. The dimples of the spot weld showed up nicely. Then hit it with the spot weld drill.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Feb 2003 Posts: 1,391 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,391 | While the floor was out I replaced the battery. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 |
Good work there John. Looks like a Heidts.
Take note fella Bolters: If you profit from these pics or any other pictures posted on this website just remember to pass on your experiences, successes or failures as you maneuver through the process of Boltism. I know some of you don't have a camera and some may not even know how to spell camera and that's OK. I have found a camera to be as important in reconstruction as my ball-pein hammer was in destruction. Share the love---share the pics.
~Jim
| | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | Went to look at fenders for my 55 1st ....bought the whole truck 55 1st 3/4 ton stake bed ....5 window...
" STUCK IN THE '50'S "
| | | | | Joined: Aug 2013 Posts: 217 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 217 | Was looking under the hood of my '55 2nd 3100, admiring my handiwork, when I noticed the alternator was hanging at a funny angle. Seems the long 3/8 pivot bolt had snapped off back inside the head. Im thinkin that I am pretty much SOL, no room to get a drill anywhere near enough to drill for a easy out, without taking half the front end off. Just for giggles I squirt some penetrating oil on the bolt fragment, which has broken off about 1/8in back in the hole. I take a screwdriver and start turning it in the hole, not really thinking that this is going to work. Darn if that thing doesn't look like it is closer to the surface now? Grab the broken bolt and stick it in the hole, and turn the broken part right on out! Maybe I need to head to Vegas? | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | got the front wheel off of my truck and found almost brand new brake pads!!!!!!!!! so all i have to do is rebuild wheel cylinder and i'm good to go (for this wheel anyway)!!!!!!! Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Feb 2008 Posts: 202 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 202 | I am finally installing my dual action fuel pump with all new lines for vacuum , fuel to carb and back to the tank and distributor advance. Next is to give it a service, check valve setting, change oil and filter, grease all frame points, do a nuts and bolts check on the new box that was installed 2 years ago,( I have been hearing a rattle from the back of the truck) clean and set points and check timing. Adjust fan belt, a little loose, oil generator caps, repack distributor grease packing cap, check rear end oil,ect.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
