10 members (MickeyP, 32Fordpuchoptop, Steelonsteel, Hotrod Lincoln, DennisM, Tronman, JW51, Otto Skorzeny, Charles in CA, 1 invisible),
104
Mod | | | Forums66 Topics128,042 Posts1,055,505 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 48 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 48 | Hello Stovebolters, I have a 1958 Chevy 235 6 cyl engine in my 1936 pickup & just installed a 22" glaspack muffler on it & I don't like the sound of it; I want the old time glaspack sound of the low mellow tone; I am going to go with headers eventually but first I want to find the right mufflers; can anyone out there give me some advise on what to get? Thanks for your help. Bebop40 | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | In my experience, the shorter the tailpipe after the muffler, the mellower the sound. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Maybe a longer muffler or even a steel pack is what you are looking for. steel pack | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Try getting a smithy's glasspack? | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Aug 2010 Posts: 70 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 70 | | | | | | Joined: Dec 2011 Posts: 133 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 133 | I used Smithy's with headers and have that old time glass pack sound but it took about 500 miles on them to get it.
If you never tell a lie, you never need to remember what you said.
| | | | | Joined: Jan 2012 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 162 | You got to get it good and hot so all the "glass" starts breaking down, then it will sound just right!! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | got same set up as Bart. (headers/Smittys) The first few years I ran STRAIGHT pipes on the 37 but decided to put the Smitty's on it. They burnt out pretty good now  | | | | | Joined: Apr 2008 Posts: 99 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 99 | the red paks with the woodpecker.. is this allowed? I went for a ride in the backseat of a 57'Chevy with glasspacks. it sounded great, but I couldn't hear a thing when we got to Santa Cruz. Now, I think it's hard to beat the sound of a Chevy V8 with Dual One chamber Flowmasters and 3"exhaust from the collectors back.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I put headers and the Thrush welded on the BB in my bus, sounds good to meBill | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | "Now, I think it's hard to beat the sound of a Chevy V8 with Dual One chamber Flowmasters and 3"exhaust from the collectors back."
That's what I run with an "H" pipe. Sounds great at 2000rpm cruisin the streets.
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | yes, put the mufflers as far back as you can get them, I actually ended up with 4 mufflers, a set of cherry bombs up pretty much directly under the cab, which sounded just awful. So I got some generic 18" magnaflows which due to packaging constraints ended up AFTER the rearend, it is very nice now, if not a bit TOO quiet. I am pretty sure I could just take the cherry bombs out with little or no effect, but it just doesn't really matter that much to me. On a side note, the magnaflows which aren't really the cheapest items that can be had. Needed to be welded up at various seams right out of the box, as this pesky little detail was missed at the factory. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I have a split stock manifold, 2.25" ID pipe and pair of 30" Smithy's under the cab. Boy was it loud. lol. Slipped in a pair of Khrome Werks 2.25" OD HP Plus drag pipe baffles right after the glass packs and it now sounds perfect. If I decide to go quieter, I'll slip in a second pair of the same baffles turned 90° immediately after the first set. Here's the entry on my blog with the details and pics - http://rustyfiftyone.com/trading-one-leak-for-another-is-exhausting/ | | |
