8 members (Gdads51, frogfarmer, Hotrod Lincoln, rfs56trk, JoeDude, Jon G, TexasA&M48Truck, dt235sd), 139 guests, and 3 robots.
Topics128,038
Posts1,055,536
Members48,425
#977124 10/07/2013 11:52 PM
Hello Stovebolters, I have a 1958 Chevy 235 6 cyl engine in my 1936 pickup & just installed a 22" glaspack muffler on it & I don't like the sound of it; I want the old time glaspack sound of the low mellow tone; I am going to go with headers eventually but first I want to find the right mufflers; can anyone out there give me some advise on what to get? Thanks for your help. Bebop40
bebop40 #977127 10/07/2013 11:59 PM
In my experience, the shorter the tailpipe after the muffler, the mellower the sound.
Maybe a longer muffler or even a steel pack is what you are looking for.
steel pack
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Try getting a smithy's glasspack?
My 46 GMC on Photobucket
porters are good also
Redryder pix
My Hotrod
bebop40 #977510 10/09/2013 12:47 PM
Purple Hornies!!
I used Smithy's with headers and have that old time glass pack sound but it took about 500 miles on them to get it.
If you never tell a lie, you never need to remember what you said.
bebop40 #978330 10/13/2013 12:19 PM
You got to get it good and hot so all the "glass" starts breaking down, then it will sound just right!!
got same set up as Bart. (headers/Smittys) The first few years I ran STRAIGHT pipes on the 37 but decided to put the Smitty's on it. They burnt out pretty good now smile
the red paks with the woodpecker..is this allowed?
I went for a ride in the backseat of a 57'Chevy with glasspacks. it sounded great, but I couldn't hear a thing when we got to Santa Cruz.
Now, I think it's hard to beat the sound of a Chevy V8 with Dual One chamber Flowmasters and 3"exhaust from the collectors back.
I put headers and the Thrush welded on the BB in my bus, sounds good to me
"Now, I think it's hard to beat the sound of a Chevy V8 with Dual One chamber Flowmasters and 3"exhaust from the collectors back."
That's what I run with an "H" pipe. Sounds great at 2000rpm cruisin the streets.
bebop40 #982946 11/01/2013 11:47 AM
yes, put the mufflers as far back as you can get them, I actually ended up with 4 mufflers, a set of cherry bombs up pretty much directly under the cab, which sounded just awful. So I got some generic 18" magnaflows which due to packaging constraints ended up AFTER the rearend, it is very nice now, if not a bit TOO quiet. I am pretty sure I could just take the cherry bombs out with little or no effect, but it just doesn't really matter that much to me. On a side note, the magnaflows which aren't really the cheapest items that can be had. Needed to be welded up at various seams right out of the box, as this pesky little detail was missed at the factory.
bebop40 #984153 11/06/2013 10:17 PM
I have a split stock manifold, 2.25" ID pipe and pair of 30" Smithy's under the cab. Boy was it loud. lol. Slipped in a pair of Khrome Werks 2.25" OD HP Plus drag pipe baffles right after the glass packs and it now sounds perfect. If I decide to go quieter, I'll slip in a second pair of the same baffles turned 90° immediately after the first set.
Here's the entry on my blog with the details and pics -
http://rustyfiftyone.com/trading-one-leak-for-another-is-exhausting/
bebop40 #984161 11/06/2013 10:33 PM
Ugh. That thing is happening again where posts disappear.
Here's the blog post on how I fixed my overly loud glasspack exhaust with motorcycle baffles. Sounds perfect now.
