| | | Forums66 Topics128,159 Posts1,057,037 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 239 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 239 | The Stovebolt has been great help restoring my truck. Just yesterday while reinstalling the fresh air heater I needed some assistance. I have a fresh air heater in my truck and the core was leaking. Pulled out the heater and took the core to a local shop. Core needed to be replaced. After reading numerous posts, I was not sure if the heater core could be rebuilt or replaced. The shop said no problem and ordered a new heater core. Picked it up yesterday. I installed the heater and then could not figure out the correct hose routing. Searching previous posts solved the problem. Found a diagram in a previous post showing the hose routing. Winter is coming. Again, thanks for the Stovebolt site. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....Larry, I think I need to add my Thanks as well. Life wouldn't be the same without the Bolt! | | | | | Joined: Mar 2010 Posts: 10,305 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,305 | I beg to differ. You people have been the major enablers of my now incurable addiction. I parked my rusted-out 52 twenty years ago. Then I found This Site, and started fixing it up. Now whenever I pick parts, or find a half-way decent AD for sale, I lose my mind and start buying trucks which I don't need. I have 3 of then now, and I don't seem to hunt or fish much anymore. My wife is always [censored] about all the parts, yada, yada, yada. My only retort to her is, "At least working on these old trucks is cutting into my womanizing and drunkenness." I don't know how much longer this is going to work.
