8 members (wilbur53, mason86, ndkid275, Otto Skorzeny, 32Fordpuchoptop, klhansen, Hotrod Lincoln, 1 invisible),
114
0
Mod | | | Forums66 Topics128,050 Posts1,055,676 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 172 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 172 | I have an idea. But, not sure. picture - http://sdrv.ms/17vslTK
1947 M15 Studebaker 454 4x4 1949 Chevy COE In the Stovebolt GalleryMore pix of the COE1950 Harley FL 1958 GMC LCF 455 3x2bbl 1961 Chevy C60 Tilt Cab 327 1966 Chevy C60 Tilt Cab 496 1961 Chevy K10 sb 292 1974 Harley FXE 1979 Chevy K10 sb 2007 Harley Streetglide I'm not that good but I'm slow
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Looks like a rear view mirror bracket minus the mirror. Not a stock set-up so some PO got creative. | | | | | Joined: Apr 2013 Posts: 172 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 172 | yeah, that's what I thought it was too.
...what's a "PO" ?
| | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | A dash fan mount, from one of those rubber blade fans. | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | yeah, that's what I thought it was too.
...what's a "PO" ? Previous owner.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Dec 2006 Posts: 165 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 165 | Dash fan mount. I have one with the fan on it Kevin
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Well, gosh Kevin, can we see a picture of it (thanks again for the valance) | | | | | Joined: Apr 2013 Posts: 172 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 172 | yeah lets see a picture.
that might be an accoutrement I have to have
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | looks like a fan mount to me
Bill | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I think we agree its a fan mount.... I want to see Kevin's with the fan on it... | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | what should go with that is an old time radio tube, it's a base socket for same, no telling what it was used for - where do the wires go?
Bill | | | | | Joined: May 2010 Posts: 74 'Bolter | | 'Bolter Joined: May 2010 Posts: 74 | I've never traced the wires (I guess I should do that), but there are also 2 extra switches on the dash that I have not traced, so I assume the wires might go to one of the switches. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | some PO was in radio/TV repair and used what was handy to hook up some odd accessory, maybe a light or speaker or fan
Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I'm with Bill, can't operate a "tube tester" on 12VDC. I think he used the connector and a base from a tube with some light or ? It's located like a map light, dome light?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | and for the original question from Goob, here is the whole thing, as a steering column mount item Bill | | |
