5 members (JW51, PAUL Berardi, 55shaker, Pre '68 Dave, Lightholder's Dad), 102 guests, and 3 robots.
Topics128,083
Posts1,056,329
Members48,442
#982087 10/29/2013 12:29 AM
Well, I got the tie rod straightened out pretty good but I found that one of the tie rod ends had been hammered over pretty good, making the removal of the plug difficult, and re-install even worse. I considered replacing the tie rod ends - they did show some wear. I have the type of tie rod end pictured in the "42-48 Car / 42-46 Truck" shop manual, figure 43, page 3-19. I cannot find this style in any of my catalogs. I could probably clean the threads up with a tap (1" x 18), but the taps don't seem to be readily available. Can any one help?
BobS46
I have a tie rod with the ends still on it. What do you need?
Best to send me a PM. What I have is from a 46 pickup.
I bought a new tie rod from Classic Performance Products. I bought two sets of the "modern" tie rod ends (I don't remember who I bought them from). I cut down the original tie rod and made a drag link. My set up required a 13/16" x 16 die and a 2" die holder.
JTS Machinery and Supply.
Die Holder (copy and paste): https://www.jtsmachine.com/jtswebshop/Taps_Dies/T215.asp#holder
Dies (copy and paste): https://www.jtsmachine.com/jtswebshop/Taps_Dies/T126.asp#2
1946 Chevy Half Ton
('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS)
1976 Margay Panther X, MC91B
Bob,I also will be replacing my tie rod ends and drag bar shortly (after the holidays). What did you end up doing? Was it expensive?
Thank you
Thanks to a fellow member of the forum, AChipmonk (sp?), I located some used tie rod ends. They did not seem to be otherwise available and one of mine was damaged beyond use.
My local shop did a very good job of pressin the rod out straight. Sorry that I can not be of more help.
BobS46
