0 members (),
119
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | You may never have a need to cut any ridged foam for your Stovebolt, unless you're going to use it in the roof, doors or behind the seat. But if you're getting your shop ready for winter and need to cut some to shape you will probably run into the problem of cutting it cleanly. Of course the absolute best way has always been with a hot wire but most of us don't want to go to the trouble of making a hot wire saw so we are left with using a saw or razor. The saw and it's dust makes a real mess and most razors are way to small for an inch or two of ridged foam and most of the time you end up with the foam balling up in front of the razor bladed. Somewhere along the way I decided to try a BIGGER razor and having an extra 4" Red Devil putty knife laying around, tried sharpening the edge. I have an 8" Nylon mesh deburring wheel mounted on one of my stationary grinders that was ideal for lapping in a razor sharp edge. I sprayed the blade with some dry lube http://www.blastergroup.com.au/dry-teflon-lube.html and low and behold, a couple of swipes and I had the cleanest cut I'd ever seen on ridged foam. And it stayed sharp thru the entire 4'x 8' sheet of 1" cut in 6" wide sections. http://www.pbase.com/dennygraham/image/152778351http://www.pbase.com/dennygraham/image/152778350Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you just like re-inventing wheels Denny  a cheap Olfa knife with snap-off blades does fine for rigid foam, extend the blade far enough to cut the depth/thickness needed - what most construction folks around here use, and worked fine doing daBus floor with very little mess, does nice curves and notches too Bill | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thought I'd just throw this idea out to help someone, dint think I'd have to spend the day defending my idea. If no one tried to re-invent the wheel Bill, we'd still be rolling our carts around on a slab of round tree trunk. We used a lot of ridged foam at the lab for the cryogenics. Used to make temporary dewers for LN2 and such. As I said, we would cut it with hot saws or a saw blade. This putty knife cuts shallow or deep, could cut thru a 1/8" to 4" thick piece, absolutely clean. It's ridged so it cuts as straight a line as you would ever want. It's cheap, everyone has a putty knife in their tool box. But....maybe you guys up dar know some secrets that we aren't privy to down here. Taint seen any Olfa, but down here we do got Fiskars rotary cutters: http://www.pbase.com/dennygraham/image/152781177Not deep enough for 1" and crushes edge. Snap-Off utility blades: http://www.pbase.com/dennygraham/image/152781178Went dull quick, not ridged, probably wouldn't be any good on 2" thick material and tears foam along the cut unless it's held at a steep angle. Cheap rotary cutter, same as Fiskars, not deep enough crushes edge: http://www.pbase.com/dennygraham/image/152781179Saw, straight, deep and fast but the mess is obvious: http://www.pbase.com/dennygraham/image/152781180Denny Graham Sandwich, IL
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | An electric kitchen works also...... Dan | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | "Re-invent the wheel" means there is already a wheel. Like already a knife that works. Bill was just kidding you anyway. and providing a alternate cutter for those who don't want to mess up a good putty knife. Both ideas are worth mentioning and any other ideas some folks may have. If construction guys use it, it is the best tool for the job. Can't see blades getting dull too fast cutting foam? Olfa sold "down here" by Home Depot, Sears, Grainger, Amazon, Ebay.....
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not attacking Denny, so no need for defense, just pointing out there's inexpensive tools available to do the job this is the cutter I use, actually a freebie from a local tool store, but the same as the original Olfas and quite rigid enough - cuts the 2" foam board [without any ridges] just fine with the right technique, always take at least 2 passes per cut, first one shallow - I like using a straight edge and happen to have an 8' x 2" piece of 1/4" steel a carpet layer gave me that works a treat for long cuts on any material - an electric kitchen knife as Dan suggests would do OK too, but because they're usually serrated or wavy edged, more chips Bill | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ALL seem to be good idea's depending on the situation. I'd surely sharpen up a wide puddy knife before I'd drive 15 miles one way to get something else! You guys quack me up! I'm gonna name you "yeng and yang" or peat and repeat!
Gosh, I just love it when new idea's pop up. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Yes all great ideas for sure. A few of you do remind me of Yin and Yang. Geez, My Home Depot is only 1.5 miles. A lot of these ideas are on the internet. http://www.finehomebuilding.com/how-to/video/cutting-rigid-insulation.aspxWatch the video from 2008.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Dagnabbit, every time I come up with an idea someone beats me to it. That's exactly what I was doing Bart and that's exactly the way it worked for me. Other than the way I sharpened mine and using a dry lube it's the same idea. My blade wasn't a clean new one and it had a tendency to stick and the PB dry lube solved that. Thanks for finding that video, it shows how well it works much better than my still photos do. If ya got foam to cut and taint tried it, I think you will be surprised at how much better it works than the utility knives.
DG
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Shows you have a good inventive mind. Many here will use that idea I'm sure.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | The electric kitchen knife is very nice for this. | | | | | Joined: Feb 2004 Posts: 29,851 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,851 | I ground the teeth off a worn-out 16" long power hacksaw blade, put a razor edge on the first 4" of it, and it's used for cutting Styrofoam, etc. just like Denny's putty knife. 10 years of use so far, and I think I've stoned the edge twice. Jerry
| | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | May try that with the insulation, got some to do and last time it was messy with razor knife. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Let us know how it works out for you John. I'll never use anything else to cut insulation, no matter what form it comes in.
Denny G
| | | | | Joined: Mar 2010 Posts: 10,299 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,299 | I think the key to the success of your modified putty knife is the curve in the cutting edge which provides for a better slicing action compared to a strait blade. Also the large handle and the overall shape of the putty knife allows you to manipulate it until you reach the sweet spot angle for efficient cutting. And don't fret not getting credit for not getting credit for inventing it. My father-in-law came up with the idea for the cardboard grease gun refill tube as a child, submitted his idea to a magazine that was asking for tips and new ideas. Low and behold, a short time later there was cardboard grease tubes everywhere. I invented the two wheeled wheelbarrow on the floor of a hardware store many years ago. Still waiting for the royalty checks that ain't coming.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | And a short memory, did I step on our toe Gary??? If I did, sorry buddy.
Denny G
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | No problem, just running my mouth. My skin is very thick. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Making a perfect clean edge of any desired angle on rigid insulation board is accomplished by using a table saw with a combination blade. Intuitively one would think it would melt the foam, but it doesn't. Try it you'll like it. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | A little saw dust in your shop Paul??????
DG
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | It creates no more dust than when cutting wood. You've got to break a few eggs to make an omelette. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Paul, this thread was started because Denny invented a way to make omelettes without eggs  Bill | | |
