| | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#97594 10/13/2006 9:38 PM | Joined: May 2006 Posts: 30 Junior Member | | Junior Member Joined: May 2006 Posts: 30 | My turn signals quit working. Actually they would work every once in awhile. So I checked the turn signal switch and found bare wires from the previous owner. So I replaced the turn signal switch and the wires down the steering column. Also replaced the flasher. now they don't work not even every great once in awhile. what should I check next? I am considering rewiring the whole truck it is a 59 1/2ton stepside. | | |
#97595 10/13/2006 9:53 PM | Joined: Apr 2005 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 82 | In replacing the flasher, check to make sure that you did not dislodge the connector that goes over to the back of the ignition switch that provides power to the turn signal circuit.
Secondly, check the connector at the engine side of the firewall that supplies power to the front and rear harness assemblies.
Good Luck,
Richard 58 3104
#97596 10/13/2006 10:46 PM | Joined: May 2006 Posts: 30 Junior Member | | Junior Member Joined: May 2006 Posts: 30 | I forgot to mention my park lights still work but just when I put the blinker on they don't light up on the dash nor do the blinkers them self light up | | |
#97598 10/14/2006 4:38 PM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | Turn signal lights work the brake lights in the rear and their own filiment in the front. Any thing from no power in to bad wires to bad grounds at the bulbs will stop the signals.
"It ain't a truck if you can't hose out the cab."
#97599 10/14/2006 5:38 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Do the brake lights work? If they do, the wiring from the turn signal switch to the rear of the truck is OK and the problem has to be in the flashing circuit itself. | | |
#97600 10/14/2006 9:02 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | It sounds like a short or a bad ground.
I'd rewire any lights that you feel NEED to work.
I had a similar problem with my truck. Blinkers didn't work very well at all, nor did the brake lights.
I rewired my turn signal switch and the entire rear end, and redid the parking lights. Everything works great now. | | |
#97601 10/15/2006 2:53 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | There would be something else coming on or smoke or a blown fuse if there was a short. More likely an open circuit. The brake lights and/or the parking lights usually won't work well with a bad ground.
Use a wiring diagram, a test lamp or VOM and logic before changing components. | | |
#97602 10/15/2006 11:28 AM | Joined: May 2006 Posts: 30 Junior Member | | Junior Member Joined: May 2006 Posts: 30 | brake lights work fine every other light works just not the blinkers that is why I thought it was in the switch. It had alot of bare wire in the switch so when I changed it I thought for sure they would work fine but you all know how that goes. | | |
#97603 10/15/2006 11:30 AM | Joined: May 2006 Posts: 30 Junior Member | | Junior Member Joined: May 2006 Posts: 30 | One other thing should the park lights light up when the headlights are on? mine don't the park lights come on when I pull the switch out to the park light position but when pulled out for the headlights they go off. I know that some of the newer models they both are on headlights and park lights but don't know enough about my 59 yet. But I am getting to learn alot. | | |
#97604 10/15/2006 5:24 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Your 59s parking light are supposed to go out when the headlights are on. | | |
#97605 10/15/2006 5:52 PM | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | check your brake light switch too.
#97606 10/16/2006 3:24 PM | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | One thing I've dicscovered over the years is the bulbs. Over time, the vibration and movement will wear the soft metal contacts on the light bulb. The bulbs will go on and off and the bulb will test good.
Look at the contacts on bottom of the bulbs. If they are "concaved" instead of "convexed", replace them.
Other weird problems with lighting many times also have to do with bad grounds. | | |
