| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 99 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 99 | 53 chev 5100 COE. I have the truck running and driving for the first time in 30 years and am having some cooling issues. I have replaced the radiator core, thermostat, cap and hoses. The engine runs fine but wants to spit water out the overflow hose. Not a bunch but enough that the fluid level goes down and the. Running temp goes up. Today I noticed that the radiator and top hose were warmer than the bottom hose but don't know for sure what that means. I have not replaced the water pump. Thanks. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the top hose should be hotter than the bottom, it means the radiator is doing what it's meant to do  pushing water out probably means you've put too much in, the fill level should be about 2" or more down from the neck to allow for expansion - check the temp around the engine and rad with a good laser thermometer to find out what the gauge is telling you, 5-10* above the thermostat rating is fine Bill | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Did you "burp" the hoses,(purge the system),when you added new fluid? I didn't,and my truck ran fine,for about a month,(after re-building the head). I drove it over 200 miles in that first month,without any problems. The day before it over-heated,i hauled a 4-ton load of railroad ties,and the gauge read the same as the ammeter. Right in the middle of the op. temp. The next day,i gave the guy,(that wanted the r.r ties delivered,a ride into the nearest town,which was only 6-miles. No problems going to town,But,on the way back, after about two miles,the gauge slowly climbed steadily,until,3-miles later,it as almost "pegged". Luckily,I pulled over,in front of a friend's house,who had a garden hose long enough to reach the place where I parked. By the time he purged the system,to rid it of air pockets,I had NO coolant left,(just straight water),but the gauge stayed below the 1/2,(cool side of operating temp.), mark. I bought 2 gallons of premium coolant immediately,and re-filled the system. I made sure to fill the radiator,(engine RUNNING at about 1,200 R.P.M.),and squeeze the upper radiator hose.This helps rid the system of trapped air bubbles,which prevent the coolant from circulating properly). It takes between 15 minutes,to 1/2-hour,but it's definitely worth it. I didn't put the cap on,until I didn't see a bubble,for 5-minutes.you'll need to wear gloves,or wrap a rag around the hose,'cause it'll get HOT. That was two Summers ago. I haven't had any trouble since then. Hope this helps.
| | | | | Joined: Dec 2011 Posts: 99 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 99 | Thank you both. Makes perfect sense, now. That's why I posted, I guess. Always good advice. A-Burping I will go. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Some members also drill a small hole in the thermostat top plate for this purpose. You can search the posts it has been discussed fairly often. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Thanks,Brad! i KNEW I was forgetting something! This will allow "trapped" air in the block,to "Escape" out of the overflow tube,via the thermostat "vent",(hole).
| | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Hey Willy...just to be clear, the 3/16" hole drilled in the t-stat plate has nothing to do with the overflow tube, unless your calling the Upper Radiator Hose the Overflow Tube??? The hole just allows trapped air to bubble up from inside the block when the t-stat is closed (engine not running), as you stated. As soon as the t-stat opens the little hole is a mute point... Mike B  | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Thanks for clarifying,Mike! | | |
