9 members (1955 1 Series, Otto Skorzeny, JW51, Greg_H, Bill Hanlon, Ponchogl, Gdads51, Peggy M, TrknGMC),
66
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,689 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#97499 10/07/2006 7:36 PM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | over the past few years,my fuel gauge would become erratic at times.I kept putting it off because i don't drive the truck everyday.Today i was at the local vendors and puchased a new sending unit for it.I installed the new one,and the gauge is working great now.I started looking over the old unit and dicovered the float has a hole in it.The hole is where the arm clips onto the float.I shook it and it was half full of fuel.I could have saved a little money just purchasing a float.I have a spare unit now and will get a float for it.If you guys are experiencing a gauge that shows 1/2 tank to full tank and the needle bounces,check the float on the sending unit,it could have a hole in it. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#97500 10/08/2006 5:06 PM | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | Thats what happened to mine. I bought a new float and it works fine. Here's a tip I found latter. If you can't find a float use a wine cork it's supposed to work.... Peter | | |
#97501 10/10/2006 5:02 AM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | I have seen old floats that were made of cork. i don't know if they were coated or not. brass floats can be repaired. or use any thing like a pill bottle or cork or cannibalize a newer unit.
"It ain't a truck if you can't hose out the cab."
#97502 10/10/2006 8:41 PM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | They sell the original brass type for $5.00 from most vendors.Mine is worn really thin where it clips on.I have considered soldiering it,just have'nt tried yet. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#97503 10/10/2006 10:32 PM | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Wouldnt the gas eat up the cork or soak into it making it heavier? Id try and solder the old one first. | | |
#97504 10/10/2006 11:36 PM | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | I have a 1961 boat gas tank with a cork float still works fine | | |
#97505 10/11/2006 2:18 AM | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | I tried soldering mine but you have to get all the holes the pill bottle trick sounds good | | |
#97506 10/11/2006 2:19 AM | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | Well for $5 go for a new one why waste your time. | | |
#97507 10/11/2006 3:34 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I've already replaced the unit with a new one. Why waste my time ? For the challenge,to see if i can .If i ruin it,i'll throw it away and buy a new one. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#97508 10/12/2006 2:00 AM | Joined: Feb 2000 Posts: 41 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 41 | This may be a naive question, but it comes from someone who is electon challenged. My fuel guage doesn't work either and I don't know what part of the system is faulty. If I pull the sending unit and lift up and down on the float arm, should my dash guage show full or empty if it's the system is working? | | |
#97509 10/12/2006 2:35 AM | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Yup, but it needs to be grounded when you do that | | |
#97510 10/12/2006 2:38 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Rusty 54, There are two components that have to work for the fuel gauge to function. If you actually have power to the gauge, try this. With the key ON, pull the wire off the sending unit. The gauge should show FULL... Now take the same wire and touch it to a good ground. The gauge should show EMPTY... If this procedure works, it means the wire from gauge to sending unit is good, and it means the gauge is working. This puts the blame on the sending unit (or its ground). These are usually just replaced..not repaired. Do some testing and see what develops. Stuart | | |
#97511 10/13/2006 2:55 AM | Joined: Feb 2000 Posts: 41 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 41 | Stuart,
Thanks, very helpful. The guage reads empty. If I detach the lead wire, no change. If I touch the lead wire to a ground, the guage pops to full. Do I have something crossed up, probably on the back of the guage? | | |
#97512 10/13/2006 3:27 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Rusty 54,
I'm not sure. Because the gauge reacts to the tests at the tank, it tells you the wire is good, and the gauge is functioning.....just backwards. I sure as heck would switch wires on the back of the gauge and see if that makes things proper.
Keep us posted...interesting.
Stuart | | |
#97513 10/13/2006 3:45 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Rusty 54,
Is your truck a GMC? If it is, are you running it negative ground rather than positive? If so, that could explain the wiring of the fuel gauge. | | |
#97514 10/13/2006 7:37 AM | Joined: Feb 2000 Posts: 41 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 41 | No, it's a chevy and all the wiring seems to be hooked up right. I'll have to tinker around with things to see what works. Thanks for the suggestions. | | |
#97515 10/13/2006 2:47 PM | Joined: Jul 2006 Posts: 13 Junior Member | | Junior Member Joined: Jul 2006 Posts: 13 | All the rigs I've worked on, ground the wire from the sending unit, the gauge should read full. Sounds like your wire and gauage is working fine. | | |
