2 members (J Lucas, pauld),
123
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 23 | Trying to figure out what size tires and rims will best fit a 1936 chevy with original rear fenders? | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | The original tire size was 5.50 x 17, the wheels were six lug artillery or the optional wire... Mike B  | | | | | Joined: May 2009 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 23 | Sorry about that not enough info the truck has a IFS front end and s-10 rear end. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I like the 215x70R 15's..... or the 235's. Depending on what your running under the hood  or the stance your looking for. I don't like using two different sizes and won't the next time but for now my 37 has 235's on the rear and 215's on he front. Been running those sizes on it for about 15 years. | | | | | Joined: May 2009 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 23 | Thanks for the info sure helps. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | It depends a lot on your ride height and track width. The only way to know what will fit is for you to measure the room you have with your wheel offsets, etc.
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | When I did mine, tire guy actually mounted 17" wheel I wanted with 275 tire so I could confirm clearances front and rear. | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | i am running a mustang 11 front with a s104x4 rear i put 235 70 15 on the back with 185 65 15 on the front with 6" rallys with 3 3/4 " bs on my 36 pickup the smaller tires on the front seames to handle better with manuel steering | | |
