5 members (55shaker, tonyt, baldeagle, DES57, Joe H), 129 guests, and 2 robots.
Topics128,040
Posts1,055,474
Members48,424
#973399 09/21/2013 6:53 PM
http://imgur.com/e3Y2yro
Got a leak today, gonna get it replaced tomorrow. Any suggestions or warnings before I start?
DJ __|__
--O-(_)-O--
'54 Chevy 3100
http://imgur.com/5XR6yO3
FPMnky #973400 09/21/2013 6:59 PM
Sir Searchalot
Sir Searchalot
Yes WARNING: Post with specifics. Where is the leak? and what is "it". If you are talking about the cover leaking, it's drain, remove. scrape, put on new gasket..... If it's axle seal, or pinion seal...more work.
FPMnky #973403 09/21/2013 7:07 PM
Gonna get what replaced tomorrow?
FPMnky #973420 09/21/2013 8:12 PM
http://imgur.com/VbYBGim
http://imgur.com/JjuLJtL
Take a look at the photos
The rear axle gasket
I think the transmission rear seal is leaking.
What do y'all think?
DJ __|__
--O-(_)-O--
'54 Chevy 3100
FPMnky #973426 09/21/2013 8:31 PM
Gas Pumper
Gas Pumper
There is always caulk, but I would for sure heed these experts advise and tell us the source of the leak.
If its...
A) Leaking from the bottom of the cover, then remove the cover, scrape, get new gasket and clean everything while you are at it.
B) Leaking from the pinion (driveshaft connection) then you need to remove the large nut, replace the seal and if there is pitting on the pinion, add a sleeve.
C) Leaking from the axle (one side or another as evidenced by gear oil on and around the hub, replace axle seals and bearings on both sides just to keep yourself from doing it again soon.
No matter where the leak is, take the opportunity to decide if its time to look at other seals and bearings that could bite you sooner than later. A reputable shop will suggest these things but don't spend more than you should. Hope this helps!
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
FPMnky #973432 09/21/2013 9:05 PM
Thank you Deve, I assumed yall could tell from the pictures. Its dark already, I will have to crawl under there tomorrow and I will get back to yall
Thanks for the responses.
DJ __|__
--O-(_)-O--
'54 Chevy 3100
FPMnky #973435 09/21/2013 9:12 PM
Hey where can I put more Trans fluid in just in case its too low?
DJ __|__
--O-(_)-O--
'54 Chevy 3100
FPMnky #973436 09/21/2013 9:15 PM
Sir Searchalot
Sir Searchalot
I don't know anything about closed driveshaft leaks if that's what you are talking about. There are many here who do, but the first thing they are going to say is "get a repair manual" so you know what the procedure is for talking apart whatever you take apart.
FPMnky #973438 09/21/2013 9:16 PM
'54 Chevy 3100
3 Speed Manual Transmission
Everything is original
DJ __|__
--O-(_)-O--
'54 Chevy 3100
FPMnky #973443 09/21/2013 9:26 PM
according to your pic. The collar is unscrewed from the trans bell.The manual will show you how to install new bell seals.
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
FPMnky #973451 09/21/2013 9:38 PM
Gas Pumper
Gas Pumper
I am not very well versed at auto trans meets torque tube, but it would seem its either Oakie Bushing.. related to the end of the torque tube, or Rear Transmission seal.. related to the transmission. Just guessing. Others here will tell you what they think. Is the leaking fluid RED or Oil colored? LOL!
Deve
The Think Tank
FPMnky #973452 09/21/2013 9:41 PM
As mike mentioned the packing nut is completely unscrewed and drifter all the way back.
The leak at the ball does not look that bad.
Try reattaching the packing nut and watch how much it leaks.
Even when everything is replaced they tend to seep some.
My Blog
FPMnky #973453 09/21/2013 9:44 PM
Its my opinion you have a bad seal up at the transmission bell as Mtneermike mentions.... and its blowing back all over everything else. First things first....take care of the bell on the enclosed driveshaft, and if you do not have a manual you can go here until you get one. At least you'll know whats involved and know what the garage guy is talking about.
http://chevy.oldcarmanualproject.com/
FPMnky #973463 09/21/2013 10:14 PM
http://imgur.com/ITzWpR9
http://imgur.com/PBTYepy
http://imgur.com/etPQu5r
Ok so I see the collar now. What about the other leaks?
Forgive my ignorance. What is "the ball"?
Where would the rear trans seal be located at?
I'm reading the shop manual now, thank you very much Achipmunk!
DJ __|__
--O-(_)-O--
'54 Chevy 3100
FPMnky #973464 09/21/2013 10:17 PM
Sir Searchalot
Sir Searchalot
Some said bell and some said ball. I see it's called the ball assembly. It's bell shaped. Sorry. The transmission has pipe plugs in the side to fill and drain, see manual.
FPMnky #973473 09/21/2013 10:37 PM
The term universal joint "ball" is quite satisfactory, if not simply the correct terminology. Follow that procedure and the leak will be less than a infrequent drip. Having no drip is rare. If you have enough transmission fluid in the bell/ball assembly (fed from the transmission) you will not be drip free for long.
FPMnky #973479 09/21/2013 11:19 PM
When I follow the procedure, I get no leak at the ball. The leak I get is at the rear collar. That collar slides back and forth on the torque-tube cover. Some people use an o-ring instead of the seal provided in the gasket kit. I do not know if the o-ring eliminates drips.
FPMnky #973534 09/22/2013 9:48 AM
Hey what do y'all suggest using to tighten up the collar with?
DJ __|__
--O-(_)-O--
'54 Chevy 3100
FPMnky #973543 09/22/2013 10:09 AM
Your hand.
FPMnky #973545 09/22/2013 10:14 AM
ODSS Lawman
ODSS Lawman
Using the procedure in the manual, hand checking the balls tightness, is critical to get a joint leak free. This process took a while for me, mostly because my collar (around the ball) was bent. Check that when you have it all apart, saves a lot of time....
Also, when you have everything back together, make sure you fill the ball with a pint of gear oil per manual.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
