1 members (baldeagle),
98
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | http://imgur.com/e3Y2yroGot a leak today, gonna get it replaced tomorrow. Any suggestions or warnings before I start? | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Yes WARNING: Post with specifics. Where is the leak? and what is "it". If you are talking about the cover leaking, it's drain, remove. scrape, put on new gasket..... If it's axle seal, or pinion seal...more work.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Gonna get what replaced tomorrow?
| | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | http://imgur.com/VbYBGimhttp://imgur.com/JjuLJtLTake a look at the photos The rear axle gasket I think the transmission rear seal is leaking. What do y'all think? | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | There is always caulk, but I would for sure heed these experts advise and tell us the source of the leak.
If its... A) Leaking from the bottom of the cover, then remove the cover, scrape, get new gasket and clean everything while you are at it.
B) Leaking from the pinion (driveshaft connection) then you need to remove the large nut, replace the seal and if there is pitting on the pinion, add a sleeve.
C) Leaking from the axle (one side or another as evidenced by gear oil on and around the hub, replace axle seals and bearings on both sides just to keep yourself from doing it again soon.
No matter where the leak is, take the opportunity to decide if its time to look at other seals and bearings that could bite you sooner than later. A reputable shop will suggest these things but don't spend more than you should. Hope this helps! | | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | Thank you Deve, I assumed yall could tell from the pictures. Its dark already, I will have to crawl under there tomorrow and I will get back to yall
Thanks for the responses. | | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | Hey where can I put more Trans fluid in just in case its too low? | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I don't know anything about closed driveshaft leaks if that's what you are talking about. There are many here who do, but the first thing they are going to say is "get a repair manual" so you know what the procedure is for talking apart whatever you take apart.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | '54 Chevy 3100 3 Speed Manual Transmission
Everything is original | | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | according to your pic. The collar is unscrewed from the trans bell.The manual will show you how to install new bell seals.
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I am not very well versed at auto trans meets torque tube, but it would seem its either Oakie Bushing.. related to the end of the torque tube, or Rear Transmission seal.. related to the transmission. Just guessing. Others here will tell you what they think. Is the leaking fluid RED or Oil colored? LOL! | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | As mike mentioned the packing nut is completely unscrewed and drifter all the way back. The leak at the ball does not look that bad. Try reattaching the packing nut and watch how much it leaks. Even when everything is replaced they tend to seep some.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Its my opinion you have a bad seal up at the transmission bell as Mtneermike mentions.... and its blowing back all over everything else. First things first....take care of the bell on the enclosed driveshaft, and if you do not have a manual you can go here until you get one. At least you'll know whats involved and know what the garage guy is talking about. http://chevy.oldcarmanualproject.com/ | | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | http://imgur.com/ITzWpR9http://imgur.com/PBTYepyhttp://imgur.com/etPQu5rOk so I see the collar now. What about the other leaks? Forgive my ignorance. What is "the ball"? Where would the rear trans seal be located at? I'm reading the shop manual now, thank you very much Achipmunk! | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Some said bell and some said ball. I see it's called the ball assembly. It's bell shaped. Sorry. The transmission has pipe plugs in the side to fill and drain, see manual.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The term universal joint "ball" is quite satisfactory, if not simply the correct terminology. Follow that procedure and the leak will be less than a infrequent drip. Having no drip is rare. If you have enough transmission fluid in the bell/ball assembly (fed from the transmission) you will not be drip free for long. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | When I follow the procedure, I get no leak at the ball. The leak I get is at the rear collar. That collar slides back and forth on the torque-tube cover. Some people use an o-ring instead of the seal provided in the gasket kit. I do not know if the o-ring eliminates drips.
| | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | Hey what do y'all suggest using to tighten up the collar with? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Aug 2004 Posts: 1,417 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,417 | Using the procedure in the manual, hand checking the balls tightness, is critical to get a joint leak free. This process took a while for me, mostly because my collar (around the ball) was bent. Check that when you have it all apart, saves a lot of time....
Also, when you have everything back together, make sure you fill the ball with a pint of gear oil per manual.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | |
