| | | Forums66 Topics128,098 Posts1,056,165 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 3 New Guy | | New Guy Joined: Aug 2013 Posts: 3 | New to the site, new to restoration with nooooooo automotive experience. Found a 50 chevy styleline and a 52 1/2 ton. decided to do a frame off with the truck. The car on the other hand is a true barn find with original interior. Needed an exhaust from front to back. So I contacted Natl Chevy and they sent me what I needed. I just don't know where the bends and in what order they get installed once I drop off the manifold. Can any one (after you finish laughing) send me a diagram or photo showing what the travel of the exhaust looks like from front to back.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Been a while since I worked on an early 50's. The "header pipe", the one that connects to the exhaust manifold is the first one and should be easy to tell which it is since it bolts to the exhaust manifold. That header pipe will run down and back to somewhere around the area under the driver's seat. Depending on how many pieces were sent you, you should be able to tell how the rest of it goes together due to the pipe where it bends over the rear axle.
Good luck. I'm sure you can do it..... and oh, in case I haven't welcome you to the Stovebolt...welcome to the best old Chevy truck site on the web. Good luck. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Yes, what was said by Achipmunk. Once you lay it all out it will become rather straight forward. One tube with a big hump bend over the rear axles, muffler and an "L" shape to the exhaust manifold. That is back to front. Or the way that Achipmunk said, front to back:"L" bend to the front, muffler, then the big bend over the rear axle. Simple really.
Steve H
| | | | | Joined: Oct 2012 Posts: 57 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 57 | you should be able to lay the parts out and do some measurements and tell where the pipes and hangers go.. i just finished a 51 styleline. i went with the fenton manifold's so i had to run duals, pictures of mine would be no help to you | | | | | Joined: Aug 2013 Posts: 3 New Guy | | New Guy Joined: Aug 2013 Posts: 3 | Thanks for the help. I should have her running soon..... | | |
