5 members (52Carl, GradyB, GRNHydra, Pre '68 Dave, DadsFirstPickup), 82 guests, and 1 robot.
Topics128,080
Posts1,055,944
Members48,430
V
V Offline
Went to swap out my left side window glass last night and noticed the 4 screws that secure the window frame to the regulator had some odd-ball tooling holes. They don't look like rounded phillips and an allen wrench doesn't work. I tried a modified allen wrench but after a try or 2 decided not to round out the hole.
I haven't started searching yet but figured the stovebolt would be the 1st place to start.
see if it's on this list - maybe the glass has been replaced in the past and someone used what was handy
If I remember correctly those are small clutch head bolts that hold the window frame to the regulator. Do a search and you will see lots of previous discussions about "clutch head" screws and bolts on this forum.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
These 4 clutch heads are difficult to remove because they rust in, spray them with penetrating oil. The are very short about 1/4" long but always exposed to weather. If they don't loosen and start to round off use vice grips to get them turning. With the cardboard removed there is a narrow slot just below the opening to access them with window rolled down about 2".
V
V Offline
Thanks for the replys.
Belated update, they are definitely clutchhead screws and as been posted bits and drivers are readily available online.
Instead of ordering and waiting for them, I went ahead and used a small vise grip to break them loose and I had a square bit that was just big enough to fit and turn them out. Got the new to me and uncracked drivers side window installed and tightened everything back up w/the square bit & vise grips.
I was so motivated that I reinstalled the new to me custom side panels and I got to say the old gal is looking pretty good now, for a weekend cruiser grin
Dave
Moderated by  ndkid275, Phak1
