0 members (),
116
Mod | | | Forums66 Topics128,105 Posts1,056,541 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I am going to try to repair my 41 gas tank. It has several pin holes, I took a dental tool to it and punched several times into it. I looked at buying new but the shipping to AK was more than the cost of the tank so I thought I would try a repair. Any thoughts or suggestions are welcome. I will steam it first. What are the thoughts, weld, solder? Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I had a number of holes in the tank of my '38 coupe. At the time a new tank wasn't even made so the only option I had was to repair. I had the holes brazed shut, acid cleaned the inside then lined it with RedKote. It's been eight, going on nine years now with no problems.
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Well, I can braze, I'll try it that way. I was thinking of using the por 15 tank repair, our napa has them. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | POR 15 seems to be a good product. I've not used it personally but I haven't heard anything bad about it. Just be sure to follow the instructions. Those who don't sometimes have the liner fail.
| | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | If you have a mig or tig welder that uses argon or mix gas ,use it to purge the tank when brazing or welding.It will displace the oxygen and will greatly reduce the danger of explosion or fire. I have also filled them with water ,but prefer to purge.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I didn't braze the pin holes in my 37 tank back in the late 90's and used the POR15 kit. Follow the procedures to the "T" and it has now worked for almost 15 years. It was just what I had at the time. I know other ways are just as good and if I had it to do again I'd certainly have brazed the holes first before doing the por15 thing. Good luck. YOu can do it. | | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | I had mine relined and it lasted for about 5 years . The pin holes came back. I bought a repair kit from Napa for gas tank repair. It worked and I cannot smell any gas .It has been a year so far so good. | | | | | Joined: Mar 2013 Posts: 30 New Guy | | New Guy Joined: Mar 2013 Posts: 30 | Do not worry about the pin holes. POR15 will fix it, and ot will seal anything on the inside siurface, like rust. Did mine 15 years ago. | | | | | Joined: Feb 2012 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 96 | JB weld or some of the gas tank patch putty get it clean and the glue type stuff works well. I fixed pin holes in my MG tank with tank sealer just have to get it good and clean first. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
